Archive
I’m trying to repair a corrupted Outlook 2007 using Scanpst.exe file. I’ve tried running it for 3 consecutive times and then detecting errors and repairing the file at the same time. I plan to do this until Scanpst can detect no errors, which might result positive outputs in the past. However, on the 4th run, Scanpst reported several errors were found but there were no options to repair the file, and the backup file selection was grayed out. The only available selection was to press “OK” which simply results to the exiting of the Scanpst without repairing anything. I’ve...
Read more
I recently received this kind of error message every time I connect a device to the USB ports (see below). I am using RocketDock and it is working fine. Please help me.
I can’t use my USB ports which is driving me crazy. Rocketdock.exe – No Disk There is no disk in the drive. Please insert a disk into drive DeviceHarddisk4DR5.
Read more
Hi there! I can send messages from my iPhone to a Microsoft Exchange account. But whenever I try to send an email with an attachment, I always get the error: "Cannot send mail: An error occurred while delivering this message. ” I’ve searched the internet for any possible solutions but didn’t manage to find one that works.
Hope you can help me solve this problem, thanks.
Read more
We are currently in the process of transferring our e-mail system to Google. We consulted a number of experts regarding this matter and they advised us that it is impossible for us to integrate the systems using Google Calendar with Luminis 4.3. I guess if it this doesn’t work then we could use our Sun Java Calendar (from Suite 5). If you have knowledge about providing Calendars to persons using Google apps then please help us regarding this matter. Thanks a bunch to those who can help.
Read more
I’m having problems regarding Microsoft Office.
The drive which I previously used in my computer is now in another computer working as a slave drive.
I’ve recently installed Microsoft Office, the same one as to the one in my old computer.
Now, what should I do to get the files in my old Microsoft Office?
Is there another way like copying key files and folders, and setting it to the same configuration the same one in my old Microsoft Outlook?
Thanks to those who can help.
Read more
I’ve upgraded all the hard drives, and drivers in my laptop then all of a sudden my laptop has finally established a connection to my wireless router.
I was just so used to connecting it that I didn’t think much of it until today.
I have realized that I forgot to put a password in it.
So, is it possible for my NIC card to have some kind of flash unchangeable RAM that keeps this info?
I’ve examine my router’s configuration page to see if my wireless encryption and password is enabled, which is actually ok.
Also, I’ve reinstalled Windows, and it recalled my...
Read more
Hello everyone,
I need your help in answering these questions of mine. How do I export usernames and passwords in clear text format from Luminis LDAP?
The employees at my company are currently using Active Directory for authentication purposes via Luminis. Is there any other ways for a user to change his/her password in Luminis and at the same time can update his/her password in Active Directory?
Please give me your answers.
I really need help.
Read more
Hi there! Unfortunately, I removed a file from my computer by mistake. My Windows XP computer doesn’t have Deep Freeze (an application which reverts my computer’s setting at boot up). Is there any way for me to recover the deleted file? Thanks a lot to those who can give me a hand.
Read more
To all MS Access Experts, I need your help in creating a multiple charts using Access, which I will also use in PowerPoint. To those who are confused as to what I’m trying to do, I want to write a routine that makes and updates charts in PowerPoint by using the data from Access queries. Please help me regarding this issue. Thanks a lot.
Read more
I have a worksheet with lots of item numbers and other forms of data from our Australian website. On my other worksheet, I have the item numbers from Italy and the correlating Australian items.  What I want to do is to create a formula that will automatically fill the correlating Italy item numbers into an empty column on the primary worksheet. I don’t have any clues on how to do this, but doing it manually will definitely take me ages to finish. So, is there another way to have the Excel import data from another sheet to pull the...
Read more
