Archive
Hi there! I want to know how to use char13 in Microsoft Access 97 but I don’t know how it was encode. At first, I thought it was written as “chr(13)” but it won’t work. So, does anyone here know how to write it correctly in Access 97? And also, kindly include a working code as an example. Any form of help would be deeply appreciated.
Read more
I have an Excel spreadsheet which requires a large a number of cells to be filled in with important data’s. For some reasons, every time I save my progress, the important data in the cells are missing. Is there another way to prevent it from being saved until all the cells are filled in?
I am only a novice when it comes to using Excel, so any guide or any form of help you can give would be very helpful.
Also, if you think there’s something wrong with the way I do my work, please point it out to me. I’d...
Read more
In Excel, I want to redo the matching rows (Rows A to C) in a spreadsheet imprinting any sheet of the workbook. Also, whenever I try to do that, I am unable to choose different sheets at the same time. I also tried selecting all the sheets and tried printing them but still no luck. It appears that this is a “sheet only property.” Is there any other ways aside from this? I’d be grateful to those who can help.
Read more
Hi there! I have six comma delimited files in CSV extension on my desktop. I want to fuse these six files together into one and load them into Microsoft Excel. Currently, I am opening all six files into one Excel file then copy-paste the contents into the first book, copy-paste, and copy-paste and so on and so forth. I figured there has to be another way, so I’m asking all of you to teach me how to fuse multiple CSV files into one Excel file. Thanks to those who can help.
Read more
Hi everyone! I would like to raise a question regarding OLAP server with HTTP connection source data and its related security. My source data currently runs on IIS6 under an IUSR account. One of my users is doing an “Export to Excel” job from an OWC11 cube on the web along with its data source. The user then forwards the spreadsheet to other users who also have access to the cube. How can I make security measures that will allow the first user to download the Excel (with or w/out the use of connection strings) at the same time,...
Read more
I just bought a 40GB Image Teradata Express 2 months ago. After frequent usage, it’s started to run out of space already. I would like to ask if anyone of you knows how to upgrade my 40GB Image Teradata Express to a 1TB Image Teradata Express. Also, please recommend to me safe and reliable methods in upgrading my 40GB Image Teradata Express. Thanks a bunch to those who can help.
Read more
I have been using the Retro software to backup the Windows XP computer to an external hard drive. Recovery from trojan attack made me to think making a recovery CD. So after the system recovery, I backup all the files and proceeded to make a CD. I have the recovery partition on the hard drive and also have installation CD. In the process of making the CD Retro prompted to insert the installation CD and redirected itself to the recovery partition.
But I got an error that the file would be too big to fit on a cd and asked...
Read more
My Server 7.7.341 with two Mac 6.3.029 clients ceases functioning during Proactive backup after copying a few MBs. I am able to successfully complete manual backing up. The error details are as follows:
- 9/28/2011 12:44:36 PM: Copying Users on MAC1
Can't save Snapshot tree, error -1102 ( drive missing/unavailable)
9/28/2011 12:48:03 PM: Execution incomplete
Completed: 5 files, 25.3 MB
Performance: 151.7 MB/minute
Duration: 00:02:45 (00:02:36 idle/loading/preparing)
Every time the Proactive backup starts, it produces the same error. All other Mac systems work fine. I tried recreating the backup sets, moving a client to another server, uninstalling and uninstalling the clients...
Read more
My workstation running Windows XP Professional is unable to identify the server. Running Netview of the computer produced the Error 6118 but running it on the network server will show the client workstation. The Windows firewall is disabled on the computer and I tried to enable it and add the IP and localhost address of the server using TCP and UDP. Do I need to make any settings change to correct this?
Help please.
Read more
I am using the Retrospect software for past 6 years an now I am receiving the “Assertion failure at "elem.cpp-1138” error. The details are as follows:
OS: Windows Server 2003 R2 version 5.2 (build 3790), Service Pack 2, (64 bit)
Application: C:Program FilesRetrospectRetrospect 7.7Retrospect.exe, version 7.7.562
Exception occurred on 28/09/2011 at 18:28:24
Error info: Assertion failure at "elem.cpp-1138"
Exception code: E0000000 ASSERTION
Fault address: 77D4DD50 0001:0000CD50 kernel32.dll
Thread ID: 00000910, Name: Execution thread
It also produces the error “There are no sufficient resources, empty stream packet, tid 71”. I have tried reinstalling Windows XP on the computer. But didn’t worked....
Read more
