Archive
Hi All,
I have a few questions on SQL 2012
1. Sql server 2012 release date
2. SQL Server 2012 - New Features
3. SQL Server 2012 Training
Thank you all
Read more
Hi All,
What's New in Microsoft Office 2010
What's New Inside Microsoft Office 2010
Can anyone help with "The Complete Guide To Microsoft Office 2010"
Thank you
Read more
Hi Experts,
What's New in Exchange 2010
Best and worst of Exchange 2010
Hands On with Exchange 2010 any documents?
Can anyone help with these?
Regards and thanks in advance
Read more
Hi All,
How to increase page rank. What are the tips & Tricks
Increase page rank Tips and Tricks?
Thank you
Read more
Hi Mate,
I have a windows 2008 Domain controller and the below error is on that system.
Process ExSetupUI.exe (PID=4216). An remote procedure call (RPC) request to the Microsoft Exchange Active Directory Topology service failed with error 1753 (Error 6d9 from HrGetServersForRole). Make sure that the Remote Procedure Call (RPC) service is running. In addition, make sure that the network ports that are used by RPC are not blocked by a firewall.
Thank you all
Read more
Hi All,
I get this error and need help how to fix it.
Activation context generation failed for "C:Program FilesSophosSophos Anti-VirusBackgroundScanClient.exe". Dependent Assembly Microsoft.VC80.CRT,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="8.0.50727.4053" could not be found. Please use sxstrace.exe for detailed diagnosis.
regards
Read more
Hi Windows 7 Experts,
We are setting up 20 new windows 7 systems and i get this error in the event log.
NtpClient was unable to set a domain peer to use as a time source because of discovery error. NtpClient will try again in 3473457 minutes and double the reattempt interval thereafter. The error was: The entry is not found. (0x800706E1)
I just want to make sure that we set up all machines with 0 issues
All systems will be in a Domain
thank you
Read more
Hi All,
I get this sophos error.
No versions of component 'MessageResDSFactory' are registered. MessageResDSFactory cannot be returned.
Can anyone explain on what this error means and how can i fix this?
I have a Windows 2003 Sp2 Enterprise edition OS
Thank you
Read more
The error message troubles me a lot with repeated entries in event log.
What is the problem with my Windows Vista that has 4 Gb ram and pretty good config system?
The Collect Procedure for the "EmdCache" service in DLL "C:Windowssystem32emdmgmt.dll" generated an exception or returned an invalid status. The performance data returned by the counter DLL will not be returned in the Perf Data Block.
The first four bytes (DWORD) of the Data section contains the exception code or status code.
Regards
Rajesh
Read more
I have this error in Event log.
The shadow copies of volume C: were aborted because the shadow copy storage failed to grow.
What does this mean
Read more
