Archive
I keep encountering the following error on Windows “WScript.exe - Application Error. The instruction at "0x750257dc" referenced memory at “0x00000008." The memory could not be read. Click OK to terminate the program.” Can any of you tell me how to fix this problem? It always shows up whenever I boot up my Windows XP computer. Any form of help is deeply appreciated.
Read more
Before upgrading my computer’s operating system to Windows 7, I was using Windows XP with Cakewalk Pro Audio 7 and VSC 3.2. Now, I’m unable to start VSC in Windows 7 despite going through all the signs of loading drivers and stuffs. Also, every time I try to run VSC, it says that the audio output cannot be opened yet. Any of you encountered these problems and manage to solve these? If so, then kindly instruct me what to do.  Thanks in advance.
Read more
Hello there! Seemingly, my Ethernet controller vanished about a month ago. This managed to get my attention when I tried to search the internet but wasn’t able to. I own a Dell XPS/Dimension 410/9200 with Windows Media Center Edition 2005 installed. Every time I turn on the computer, a pop-up message appears telling me a new hardware-Ethernet controller is found. Although this message appears, I can’t seem to find or install the said hardware. I’ve tried lots of solutions like backing up and reverting the date but still no luck. I’ve also tried reinstalling using the installation disks but...
Read more
Every time I try to download files in the internet, an error pop ups which says that I need to reinstall missing Its.dll/1ts.dll (not sure if it was an “I” or “1”). And also, when I visit Yahoo, it keeps asking me to delete cookies which I don’t know how to do. So, I would like to ask anyone how to do this “delete cookies” thing. Any of you knows how to? Thanks in advance.
Read more
Hello everyone! I own a server (Server B) that’s currently unavailable and unable to join any other domain on my forest server DC (Server A). Since I keep on receiving FSMO role error ID 2087 and for me to remove my server (Server A), I decided to use Ntdsutil to remove the metadata but still failed. My server (Server A) is still unavailable and unable to establish a connection to my forest server (Server B). I tried deleting it from domain controller OU but it still won’t allow me from removing it from the active directory domain & trusts,...
Read more
I am trying to open Adobe Reader X in my email account with my Windows XP Home Edition PC. I am receiving error message: “AppName: acrord32.exe appVer: 10.0.0.396 modname: acrord32.dll modver: 10.0.0.407 offset: 00187035” keeps popping up. I tried to uninstall Adobe Reader and reinstall it again but the error is still there. I could not even open it on my desktop. Do any of you know any solution for this? I’d be very thankful if you can help me solve this problem.
Read more
I have a computer with Windows XP Professional SP3 Operating System. All the DOS programs which I have are stored in C:XEDIT, which includes FULIST.
In AUTOEXEC.NT I edited it to “SET PATH = C:XEDIT.” Since then, every time I run the Command Prompt windows, it says C:Data for example, and enters FULIST, an error pops-up. It says "FULIST is not recognized as an internal or external command, operable program or batch file."
After that, I always type “SET PATH = C:XEDIT on the command line for FULIST to work.
And every time I close the command prompt and execute it, I...
Read more
I own a Sony VAIO VGN FW317J with Windows Vista Home Premium. Yesterday night, I wanted to turn on the light function but pressed F7 by mistake. After that, two choices came up: the first one was about LCD display and the second (which I selected) was something I forgot. Since then, I cannot log-on to my primary user account despite being able to log-on with my secondary user account. Can anyone help me with this? I really need to solve this problem as soon as possible.
Read more
My pocket PC’s current operating system is in German and I’ve decided to upgrade it into Windows Mobile 2003, and have it installed as ROM. Also, is it possible to install a UK version using my memory card? Are these two possible? If not, then can any of you give me alternative solution? Help would be definitely appreciated.
Read more
Hi friends, I need your help on how to alter my logical drives in my computer into a primary partition using EaseUS Partition Master 9.1.0 but an error keeps popping up. It says that "There is no empty slot in MBR Partition Table". Currently, there are 3 partitions in my computer, C, D and E. My Windows XP is installed in C and Windows 7 in D and the rest contains the files on my computer. I want to change my drive C from a logical drive to a primary one. Can anyone tell me how to do this?...
Read more
