Archive
I’ve been using AnchorFree Expat Shield, a VPN program which provides the user a UK IP address, for some time now without experiencing any problems.
However, yesterday the program wasn’t able to execute and a Windows error pops-up saying “Open vpntray.exe has stopped working.” I tried searching the net for any possible solution but failed.
Does anyone of here know any solution to this problem?
If so, then I’m definitely grateful to your help.
Read moreI have installed Windows XP Home Edition on my computer, without the Service Packs. My friend told me that one must have SP1 or SP2 installed before installing SP3 when running Window-based system. I’ve also read different information regarding this matter. Some say that slip streaming is the only way to go directly from XP-SP0 to SP3. Other people say that one must have SP1 or SP2 installed before installing SP3. So can anyone tell me which of this two is the most effective and safe solution? I only have one shot in doing this using nLite 1.4.8. So...
Read moreI have two Dell computers at home. Every time I put them to sleep mode, the fans turn off except for the other one, a Dell OptiPlex GX200 with a Phoenix ver. A05 BIOS.
I’ve tried searching the net about this odd behavior on my computer, and finally came up with information related to this matter. In the article that I found, it says my computer needs an ACPI enabled system which is set to S3, for the fans to be disabled during sleep mode. I’ve checked the BIOS setup and wasn’t able to find anything about ACPI, S3 or...
Read moreI recently installed Windows 7 on my Dell laptop. Since then I keep getting errors on my DVD ROM. It says on the error “Code 19: Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged.” I tried reinstalling some of the drivers but still didn’t manage to fix the error. I also tried browsing the net but the only solutions I’ve found are for Windows Vista and XP only. I’m having doubts if these solutions will work on Windows 7. I need everyone’s opinion regarding this matter. Please help me.
Read moreEvery time I boot up my Windows XP computer, the system always displays
“Explorer.exe error: This instruction at "0x015a5270" referenced memory at "0xffffffff".
The memory could not be read.”
Anyone of you knows how to solve this problem?
Please help me.
Read more
System Restore has ceased functioning on my laptop with Windows Vista OS.
Every time I run System Restore on my laptop, the system keeps on displaying “ERROR 0xc000007b: Each attempt to access System Restore on Windows Vista laptop fails with Error 0xc000007b.
Previous restore points lost.”
Can anyone tell me what this means?
I’m asking you to help me with this since I’m not pretty really familiar in using laptops and computers.
Read moreEvery time I executed the Task Manager and shutdown or restart my computer, I keep getting the message error “dwwin.exe Application error...the instruction at "0x3003a657" referenced memory at "0x00a65a4d", the memory could not be "read", click OK to terminate the program” and such. Aside from this, I’m currently unable to add and remove programs, and use other utilities in the Control Panel. I’ve tried fixing the problems by downloading software which fixes my registry, but still no luck. I’m really at the end of my wits; any form of help is deeply appreciated.
Read moreI bought new HP Compaq dc7700 Convertible Minitower 3 days ago. After using it for a couple of days, for some reasons the system’s time keeps reverting even after setting it again. I’ve tried changing batteries but the problem still remains. Can someone provide me with solutions to this problem? Thanks in advance to those who can help me solve my problem.
Read moreWe are currently using Windows 7 32-bit on our computers and are also having trouble getting GS 8400 PCI express and nVidia GeForce 8400 GS PCI video cards functioning at the same time when running multiple monitors. We always keep on getting PCI bridge errors and have tried several solutions to fix the errors including changing PCI slots and others. Before upgrading from Windows XP to Windows 7, we never experience any of these problems. Do any of you have solutions or tips on how to get both cards to work continuously to run 3 monitors at the same...
Read moreI am using MSI laptop with Windows 7 installed on it. It has also a Blu-Ray Disc Drive and I want to upgrade it as soon as the new firmware is release. Anyone of you here knows how to get information about the manufacturer of your laptop’s Blu-Ray drive? I’ve tried checking the Device Manager on my computer but still no luck. I tried searching for it on Google.com but I can’t manage to find links that satisfy my problem. Hopefully, one of you here can help me. Help is definitely appreciated.
Read more
