Archive
In renewing the Cisco Certified Network Professional license, I understand that you would have to pass another 642-channel examination.
Is there any difference between the professional exam and that of the exam for field engineers?
Read moreThis online gaming platform I frequently visit recently stops functioning whenever I open it.
Eventually, I found that if I keep another browser window with another page from this site running, it will sort of solve the problem.
I would like to ask if this is an issue for the site owner to resolve?
If you have any information about this so that I can better understand and use the proper web browsing application to play the games without it being terminated mid-game?
Deleting the application and putting it in the system again is the last absolute resort.
Read moreI was using a peripheral storage device as duplicate data for a particular network storage link. Not long ago my computer system started to not recognize the integration and as a result, I tried to switch my network storage for another one. To make it functional, I had to restore my peripheral storage’s system; midway.
I realized that I was not able to duplicate some of the first files but the system had already started removing some files when I terminated the process. I would like to know if there is any way I can get back the data lost...
Read moreI assembled the computer I am using right now few days ago. The problem is it keeps on displaying a BSOD error which says that it is an “Uncorrectable Error.” I have desperately searched the net for any solution to this problem but I still can’t find anything helpful. Also, I’ve heard from a friend that this error might be caused by a hardware problem which is I’m not so sure of. I really need help with regards to this. I’d be really thankful to those who can help me solve this problem. By the way, these are the...
Read moreI have upgraded my iMac to OS X Snow Leopard 10.5.8. Since then, my computer is unable to detect any of my backup devices and I’m also unable to back-up and transfer files from my computer to my backup devices. Aside from that, when I first bought my e-SATA firmware which is Macally PHR-S100SUA, I wasn’t able to completely transfer the files I stored onto the device from my old computer (a MAC tower) to my new computer (the iMAC). Furthermore, I don’t have any more access to the files that were on my old computer. I’m really in...
Read moreI have a Toshiba Satellite E205-S1904 laptop. My problem is regarding my Intel Wireless Display.
Recently it has stopped working. I attempted to set up the most recent edition of the driver (2.1.38.0) but received an error stated below.
I have upgraded the HD graphics as well as WiFi compatibility drivers.
But it doesn’t help at all. Do you have any kind of solution for this?
Error Information:
Intel (R) Widi Installer Information
Error 1721. There is a problem with this Windows Installer Package. A program required for this install to complete could not be run. Contact your support personnel or...
Read moreI updated my Windows Vista about a year ago. And now, I cannot install the jEdit software. Every time I attempt to install it, I am facing a system error. Here's a photo with the problem concept. Anyone can help me? I am really in a big trouble!
The first prompt message box is stating:
WinZip Self Extractor [JEdit12a.exe]
Click 'Setup' to extract the files to a temporary directory and begin the J-Edit installation.
The second prompt message box is stating:
16 bit Windows Subsystem
SYSTEMCurrentControlSetControlVirtualDeviceDrivers. VDD.Virtual Device Driver format in the registry is invalid. Choose 'Close' to terminate the...
Read moreI could not open Adobe Captivate software after successfully installed it on my computer.
I attempted in order to uninstall the program to do the installation once again, however the exact same error information occurred.
A screenshot of the error has shown in below.
Can anyone solve this problem?
Error Message:
Adobe Captivate has encountered a problem and needs to close. We are sorry for the inconvenience. If you are in the middle of something, the information you were working on might be lost.
Error Signature
AppName: adobecaptivate.exe AppVEr: 5.0.0.596 ModName: dvaui.dll
ModVer: 5.0.0.0 Offset:001ab9a7
Read moreI have a Dell XPS M1530 laptop. Recently, I’ve changed the settings of my Windows Vista in order to Windows 7. At the beginning everything was perfect, my USB mouse worked properly for the days. But the entire USB ports stopped working as soon as I input a memory stick. These nevertheless produce energy; however the Windows does not identify any kind of USB device in any way right now. Do you have some answer for this?
Error message from Notebook System Software Installer Information
"Error 1327. Invalid Drive: G:"
Read moreI am trying to install A4 Tech Webcam. Once I begin to install the software, I get a message that indicates a mistake that this can be not passed the Windows emblem testing.
It recommends me to prevent the installation and contact the software vendor. My question is if I can use this software securely?
Software Installation Error:
"The software you are installing has not passed Windows Logo testing to verify its compatibility with Windows XP."
Continuing your installation of this software may impair or destabilize the correct operation of your system...
Read more
