Archive
I deleted the Kodak EasyShare Software and Kodak updater into my computer.I used the Add/Remove software characteristic on my latest Windows XP computer program. Afterwards, every time I begin to open my computer, there was a failure message running into data accounts (Kodak Device Updater.Exe) need a (id separator application). What should I do to free from this faulty information?
Read more
Hi, I am downloading LifeCam Software 3.0 through disc and this error was started when I am using the webcam, "lifecam.exe has facing a trouble and had to escape. Sorry for this interruption.” I have deleted the program and downloaded other software in Microsoft website but when I started my webcam again, the same error appears. I really need help. Thanks.
Read more
Hello guys. I am checking for an update in iTunes, and when I clicked on it, an error appears stating that
The iPhone software update server could not be contacted.
My internet connection is active as I can connect with iTunes store. The error is also stating to try again, but I am trying for almost a day and yet the error is still re-appearing.
How can I fix it?
Error message:
Make sure your network settings are correct and your network connection is active, or try again later.
Read more
I need to split a movie file so I can burn it with my DVD-R disk. What software can I use to for this? When I encode DVD to MP4 this error appears: “Error -2041: An invalid sample description was found in the movie.” And also, I cannot play any videos on QuickTime Player. How can I adjust the settings for this? Help please.
Read more
I am trying to convert .flv to .avi files and 3gp files format using H.264 Codec.
When I tried media coder (mobile version),
I got the error message “Audio and video cannot be mixed together (error 15).”
I need to solve this problem as soon as possible.
I will be using the video for a project presentation so if anyone here knows how to fix the error, please help me.
Or send me other software alternative that is capable of converting video files.
Thank you.
Read more
Whenever I played video with Windows Media Player, I am getting this error message “Failed to open VDPAU backend libvdpau_nvidia.so: cannot open shared object file: No such file or directory.” I cannot play any videos due to this error. I am using Compaq CQ20-213T with Windows XP Professional Service Pack 3. Can someone help me in this matter?
Read more
I have ObjectDock 2.0. It works like a usual dock. When I clicked my Google Chrome icon, I faced the popup error message “Google Chrome Application error 0xc0000135.” The ObjectDock works with almost all of my programs except in my Google Chrome. Is it compatible with Chrome or not? Please send me some advices.
Read more
I have tried to install AveDesk – Desktop Enhancer and got this error message
This application has failed to start because d3dx9_36.dll was not found.”
When I reinstall it before, the error is fixed. But now I am unable to re-install because of my current location.
I have downloaded the file again and place the setup on my desktop and try to reinstall it again but it seems that I need to download again the missing .dll file.
Where can I download it?
And how can I fix the error?
Read more
I want to save and edit files on a remote machine using Notepad. I have granted the security permissions and access privileges in the folder. However, when I tried to edit or save, the following error occurred: “Please check whether if this file is opened in another program.” I have tried to find solutions but failed to fix it. I really need help!
Read more
I am running Windows 7 Home Premium on my Dell laptop. The OS is pre-loaded when I purchased this. I am using FastStone Image Viewer 4.6 but I am unable to see images. This error message appeared "...not a valid Win32 application" I don’t know what type of problem is this. Anyone know how it can be fixed?
Read more
