Archive
I am attempting to open the Windows Vista Task Manager but this error appears: "The task image is corrupt or has been tampered with wavepad Shake Icon" I have a licensed version of WavePad sound editor. I purchased it 2 months ago. The error seems to be part of Scheduled Task. How and where can I disable it?
Read moreI am trying to copy a DVD movie from a MDS/MDF source file. The size of the movie is 7.4GB, and I used a DVD Rewritable disk when burning.
When I inserted the disk and started the burning process, I heard a loud noise and after that it shows the error below.
The error code is 0x052102. How can I fix this?
CDBurnerXP
(devInvalidAddressForWrite) Could not write to Disc (LBA: 32 Length: 32).
Invalid Address For Write. -0x052102
Read moreI was extracting Sony Notebook Utilities for MS Windows. I will be running this on my Windows 7 PC. I am using Universal Extractor Version 1.6 for extracting, but I keep receiving the same error on the attached image.
The extraction failed, and I could not make it work. Kindly please help me. Thank you.
Universal Extractor v1.6
H:Notebook UtilitiesSony Notebook Utilities.EXE could not be extracted.
It appears to be a(n) Wise Installer package, which is supported, but extraction failed.
Please see the log file,
C:UsersTommyAppDataLocalTempuniextract.txt, for more information.
Click OK to view the log file now, or Cancel to...
Read moreWhenever I tried to play video in KMPlayer an error is showing on my screen. And I was unable to use the minimize and maximize option also. When I clicked on OK everything will be fine. This is very irritating for me. I have the latest version of KMPlayer. The error that I am receiving is "Access violation at address 0477867D in module 'gen_ml.dll_'.Read of address 00000028." What can I do now? Please help me.
Read moreI want to install 4 on Demand Software for watching videos. But I spend almost an hour for installing with no luck. An Error 1303 is appearing during the installation. It is also stating that the installer for 4oD doesn’t have enough privileges to access the directory where My Deliveries is located. I already tried to log in as the Administrator but I can’t still continue with the installation.
Can someone please help me?
4oD Installer Information:
"Error 1303. The installer has insufficient privileges to access this directory:...
I have a Philips Raga, and I am trying to install Philips Songbird to it.
But an error occurred during the installation.
I am using Windows XP Home Premium.
I never had any problems when I installed Pure Songbird few weeks ago but when I am trying Philips Songbird, I cannot continue with the setup.
How can I correct the error?
Please send me some help.
Error on Philips Songbird Setup
"An error occurred during the installation. Please launch the installer again to install Philips Songbird."
Read moreI installed iTunes software for listening music. I am also trying to install Foobar 2000 but the installation failed. I see that the software is running successfully by various people. But mine has an error on running the installation. I am using Mac OS X Lion. The error is stating that there are some components that cannot be installed on my computer. What are those and how I can resolve it?
Error:
"Install Failed"
The installer could not install some files in "/Users/edrift/Applications/foobar2000.app/Contents/Resources/drive_c/Program Files/foobar2000/components". Contact the software manufacturer for assistance.
Read moreWhy am I receiving a (Null) Error whenever I tried to install Paint.NET on my Windows XP computer? I attached the screenshot of the error message that I keep receiving when trying to run the setup of Paint.NET. Does anyone have a suggestions or ideas on how I can mend this problem? If so, please help me.
System.IO.FileNotFoundException: Could not load file or assembly 'System Core, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' or one of its dependencies. The system cannot find the file specified.
File name: 'System Core, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'
at PaintDotNet.Setup.SetupWizard MainImpl(String args)
at PaintDotNet.Setup.SetupWizard.Main(String args) in
D:srcpdnpdn_35xsrcSetupFrontEndSetupWizard.cs:...
Read moreI am very satisfied with Comodo Internet Security 3.X but when I was prompted for an upgrade; my system is unable to upgrade my Comodo 3.X. to latest version. The following error incurs "Comodo firewall setup wizard ended prematurely because of an error. Your system has not been modified. To install this program at a later time, run set up wizard again" and a popup error "Cannot install COMODO firewall Error: 1603. Fatal error during installation. Would you like to try again? YES or NO" Do you have any suggestions? I am running Windows XP Professional SP3.
Read more
Hi Experts! I am trying to install Nitro PDF Reader on my Acer One Netbook with Intel Atom Processor and 2 GB of RAM. During the setup, the installation stops with error: “An error occurred during the installation of assembly
Microsoft.VC80.CRT,version="8.0.50727.4053",type="win32",publicKeyToken="1fc8b3b9a1e18e3b, processor Architecture="x86". Please refer to help and support for more information. HRESULT: 0x80070002.” I was searching online for solutions but I could not find anything that has the same exact situation as mine.
Can someone please provide a solution?
Thank you.
