Archive
I moved my Wubi to other partition. After that my LibreOffice 3.3 received a Fatal Error and stopped functioning with the following error:
The Application cannot be started. [Context="user'] caught unexpected exception!
I tried so much to find solutions but I always failed.
Does anyone here know how to fix this?
Error:
My wife is using Roxio PhotoSuite 8 for many years now which comes with her camera. We have recently installed Windows Vista in our computer. Now when we restarted our PC, the following error message appears: "This driver is blocked due to compatibility issues. A driver is installed that causes stability problems with your system.
This driver will be disabled. Please contact the driver manufacturer for an update that is compatible with this version of Windows.” Does this software cannot be installed in Windows Vista computer?
I have uninstalled PS5 from my Windows Vista since it is not compatible.
But this message...
Read moreI have tried to load a large number of file in Vault with Vault 5 Autoloader. Some files are loaded from my Workspace and some files are not. While I start autoloader, Vault directory asked me to show the Workspace map. I used “design directory” which is not part of my Workspace. In the existing engineering folder “FMIJobs”, “FMIPN” files are duplicated. I have tried to move the files from Engineering folder to the Design folder but I was unable to move it. I would have to map the Engineering folder but not to the Map folder. And also,...
Read moreI am using Windows Vista with AMD Athlon 7850 CPU and VGA GeForce 9600GT 1GB and 2048 MB DDR2 RAM and 640 GB HDD. I am trying to install Sony Vegas 9 on it but I keep getting an error “Requirements not meet.”
What am I missing on the setup? What are the requirements needed to install the game? Please help.
The following components are required by this software:
Microsoft WMF 11 Redist for MTP, Windows Media Audio and Video Support
Sony Setup Error:
Requirements not meet. Press OK to Exit Install.
OK
Read moreI have successfully installed Corel PaintShop Photo Pro X3 on Windows Vista. However, the program is not displaying in the list of programs. I re-installed it but my computer would hang. I tried to re-install it for the third time but it still not found in the list. Can anyone help me on how to install this?
The system cannot find the file specified.
C:UsersSteveAppDataLocalTempCorel PaintShop Photo Pro X31.5.1.001LangENCustomInit.htm
OK
Read moreI downloaded Kaspersky 2012 while I was downloading it said I needed to uninstall Kaspersky 2011 and I did now I cant find my 2012 Kaspersky
Read moreI am trying to install Quicken Starter Edition 2012 to make budgeting easy on my Windows XP computer. The problem is I keep getting an error code 2 during the setup. And then the installation will stop leaving me no choice but to start the installation again. But every time I am starting the setup, the error keeps appearing that’s why I could not continue. How can I resolve this issue?
Read moreI am using my QuickBooks for storing information and managing my profits in my transportation business.
Today, I found a Fatal Error message when I clicked QuickBooks Statement Writer.
I need an urgent help for this as I cannot skip a day to store some important information.
What should I do to correct the error?
Fatal Error
Unable to open statement: Fsd.Comrnon.FsdSdkExcepteon Unable to open connection to QuickBooks. --->
System.Runtime.InteropServices.COMException (0x80040402):
Unexpected error. Check the...
I am trying to install Kaspersky Internet Security 2012 on my Windows 7 PC. But an error is appearing after I entered the product key of the software. I am using Kaspersky on my own PC only but I have installed it for few times now. I am really puzzled because I purchased this software few months ago only. Is it expired and do I need another activation key? Please send some help. Thank you.
Activation of Kaspersky Internet Security 2012
Activation error
Number of activations using this activation code has been exceeded
Read moreMy Hp Pavilion Elite m9150f is working properly with Windows 7.
But I have some problems on my read and unread emails when using Firefox and Internet Explorer browsers.
The text is not showing as a usual text.
When I installed Google Chrome, the same problem incurs. I am unhappy with the italicized text in my Gmail Account. When I installed Turbo Tax 2011 the problem came finally to head. I attached the screenshot below.
Please send me some help.
Thank you.
TurboTax Font Verification
TurboTax has detected one or more invalid fonts and is unable to continue.
-Font 'Arial' does not...
Read more
