Archive
When I get a prompt that says the system could not locate XLQUERY when I try to access a file, and that pursuing further might lead to inaccuracies; where in the process did I make a mistake and what are steps I can take to resolve this problem?
Read more
 Is there a way to transfer an Excel file to cloud and have another user from a separate area and IP address update this file? What are the regulations in going about this process i.e. in terms of file size and the licensing charge for Microsoft 2007?
Read more
If there is a possibility of having two simultaneous occurrences of the same CRM version in one location, how is it executed? Given the equal degree of permission of two separate administrators; one for each software, what are the conditions that will affect safety?
Read more
In duplicating data, is it advisable to initially conduct a full back-up and recovery process? Please lend expert advice on what is the recommended way in the synchronization of the Storage Area Networks prior to duplication process. Thanks.
Read more
When making reports in Crystal Reports XI version and applying an Oracle SQL query, what are the usual and expected mistake prompts that will most likely appear? Will you also be kind enough to give advice on how to address these issues? Thank you.
Read more
Is it possible to conduct a reliability test to my DNS server to check if it executes correctly and efficiently using a Windows R2 server? Should this process not be suitable, can you please advise me on how I can test if my server is running accordingly?
Read more
I would like to make a memorandum with the header and footer visible only on the first page where the collective header that indicates “Print Memo” is written. How can I remove both header and footer to the page where the memo content is written?
Read more
Hi Experts,
Is there a way that I can save a single file into two separate folders but are synchronized in such a way that if the file is edited and is saved in one folder, the file in the other folder will automatically save the changes as well?
Can you please help me on how I can do this?
Thank you.
Read more
To my understanding, it is possible to disable the data memory oversight in your data warehouse.
Can you please affirm or correct my knowledge?
If possible, I also want to inquire on how to go about this process; including the migration of data to specific bins.
May I also ask for a reference of the step-by-step guide to help me with the process?
Thank you.
Read more
Suppose that 15 of our users with separate computers are required to open files using Crystal Reports, is it still necessary to have the application licensing for each of the 15 computers even if they need not make reports and only read them?
Read more
