Archive
Hi guys,
I want to download scheduler for my sql job but I don't know how to do that. Can you please tell me where I can get free sybase sql job scheduler? I need in details
Thanks
Read more
Hi to all,
I have a problem in deleting files mainly the MPASM suite.  I have tried removing it a couple of times; however, I just can’t seem to do it.  Below is the HTML code.
Language tool versions: mplib.exe v4.41
Tue Mar 27 19:02:52 2012
Clean: Deleting intermediary and output files.
Clean: Done.
Couldn't locate build tool.  Check tool locations.
As you can see at the end part, it states “Couldn’t locate build tool. Check tool locations”.  All I want is to remove a file and it is getting so annoying as I encounter this error.
Urgent help needed! Thank you very much for the time...
Read more
Hi guys,
I want to download counterstrike bildschirmschoner screensaver for my little boy. Please tell me where I can download, and better it is free.
Thanks
Read more
Good day to all,
I can’t seem to access my repositories through Subclipse. Without browsing them, importing them is also impossible. This is the error message that Subclipse gives me - “Folder does not exist remotely.”
By the way, the only thing I can do to my repository is share a project. However, I must use “svnadmin create”. Is this the way it should be? Please anyone help me. I really have no idea what’s wrong with Subclipse.
Thanks in advance to your help!
Read more
Hello Guys,
I have problems in running Object Designer.
I have tried to open it by loading my license which I scanned.
Instead of opening it, I am given this error message below.
I need your help badly.
Thank you very much.
There are errors in the text conversion because text no. 89-3257 does not exist in the .stx file.
Internal Error: 47-1
Read more
Can anyone help me with this error upon updating PDF Creator?
PDFCreator - www.pdfforge.org
Errorprotocol
PDFCreator 1.3.0 - Error message
ERROR DESCRIPTION:
          Error-Nr:    75 (Path/File accesserror)
          Module:    modPDFCreator
          Procedure:    IfLoggingWriteLogfile
          Line:         50190
          Date/Time:    03-12-2012 / 18:38:37
CALLSTACK:
SYSTEMINFO:
 Windows 7 6.1 Build 7601 (Service Pack 1)
  [TerminalServerIsWinXPPlusIsWinVistaPlus IsWinVistaSP1 IsWindows7]
The previous version I used was 1.2.3 but it had a glitch.  This specific REG file was needed to run it though.
Windows Registry Editor Version 5.00[HKEY_CURRENT_USERSoftwarePDFCreatorProgram]
"PrinterTemppath"="C:\Windows\Temp"
I am now having second thoughts on converting it back to the...
Read more
Good day,
I need some help on this error I have encountered in the a Apache error log - File does not exist: /usr/share/groupoffice/etc.  This occurred upon adding group office through Debian package in my system.
All is well except for this error.  I just want to know the reason for this error and of course the solution for this.  Your help would be greatly appreciated.
Thanks a lot.
Read more
Hi guys,
I wonder that can we open or extract rar on server, which uses windows 8 r2. If so, we use some software or scripts.
Thanks
Read more
Hi guys,
I have a HTC EVO 3D. There is something wrong with team genesis because it got boot.  I need help about team genesis evo 3d rom android. Please give me detail instruction about how to solve this problem.
Thanks
Read more
Hello Guys,
I am having issues on sending a model to FSX.  Every time I do this, I am given an error that states MakeMDL was not found.  I am then advised to check the MDL path if the file is there.
As I checked the location given by the error message, the MakeMDL files were in my plugins folder.
I think that everything is in the right place but I have no idea of why I encounter this error.  Maybe someone out there could help me.
Please.
Read more
