Archive
What is compatibility administrator in the Application Compatibility Toolkit in windows 7?
Read more
Hi there,
I have an installation problem here and it really bugs me because I have tried installing it a hundred times yet it is always ends up unsuccessful.   The program I want to install is Paint.net.
Here under is the error message.
SearchOptionsearchOption)
atSystem.IO.Directory.GetFiles(String path, String searchPattern)
at PaintDotNet.SystemLayer.FileSystem..cctor() in D:srcpdnpdn_35xsrcSystemLayerFileSystem.cs:line 506
--- End of inner exception stack trace ---
atPaintDotNet.SystemLayer.FileSystem.TryDeleteFile(String filePath)
at PaintDotNet.Setup.InstallingPage.<DoInstallation>d__21.MoveNext() in D:srcpdnpdn_35xsrcSetupFrontEndInstallingPage.cs:line 930
at PaintDotNet.Threading.IterativeTask.IterativeTaskAnon.<OnExecute>d__0.MoveNext() in D:srcpdnpdn_35xsrcCoreThreadingIterativeTask.cs:line 36
at PaintDotNet.Threading.IterativeTask`1.<>c__DisplayClass1.<StepTask>b__0() in D:srcpdnpdn_35xsrcCoreThreadingIterativeTask`1.cs:line 77
Please help me on how to install this application. Thank you very much to whoever can assist me with this.
Read more
Hi to all,
Thinking of what to use for running an INPA software, I thought of an OBD connector.  I saw an image of a 20-pin round adapter in one of the Ads in the PDF installation manual as I was reading.  It immediately gave me second thoughts on what adapter to use.
So my first concern is what connector should I use?  Maybe using the wrong connector made all these IFH XXX errors occur.  This is just a hunch though.
Here are more details of the error.  According to my instincts, the error is caused by a faulty file location or...
Read more
What is Application Compatibility Manager in windows 7?, what are the uses of it?
Read more
What is the Application Computability tool kit in windows 7?
Read more
What is disk defragment and what is the purpose of disk defragment?
Read more
What is the purpose of the disk clean-up in windows 7?
Read more
How to open device manger in windows 7?
What are the main ways?
Read more
What is Device Manager in Windows 7 and uses of device manger?
Read more
What is Windows Preinstallation Environment?, What is the use of it?
Read more
