Archive
Hello techyv,
How to connect vba access 2010?
I would like to connect my visual basic 6 calculator system in Microsoft Access 2010 database.
I need a database that will hold all the possible data to be entered and save by the system user.
Can you give me a step by step process on how to connect it properly?
This is for my office database.
Expecting some help from you guys.
Thank you.
Read more
Hi to everyone,
Where to find some active directory interview questions? Our final exams will start next week and I am having difficulty on my computer related subjects especially programming and other written technical issue exams. Can you give me an idea on where to find active directory interview questions as a basis or reference for my exam?
Your suggestion is very much welcome.
Read more
How to use this free mobile sis dictionary? I have this Nokia s60 mobile phone device, do you think that the sis free mobile dictionary is compatible with the operating system of Nokia s60? I am not sure with the security measurements of this application I hope it is safe to use.
Waiting for your support, thank you.
Read more
Hi!
I have a problem with burning a CD using Realplayer 32-bit. Along the process of burning, I am prompted with this annoying error message - “Please ensure that your disc is clean and not damaged, before attempting your burn again. If the problem persists, try burning with the option to add 2-seconds between tracks, if applicable. (1014)”.
Please help me find a solution for I am hopeless.
Thank you!
Read more
Good day!
I wanted to edit the videos that I have copied in an external hard drive from my video camera. I was shooting these videos through FS-H200 with a JVC ProHD camera. The files were in DTE format to Quicktime (.mov).
My problem now is that these files cannot be imported into Adobe Premiere CS 5.5. Whenever I do so, the error message - “Unsupported format or damaged file.” pops up. Now upon opening the files through Quicktime, another error is encountered - “Error – 2002: a bad public movie atom was found in the movie (Filename)”.
Wanting to repair the...
Read more
Hi!
I am having issues on encrypting files. Every time I open a pdf file from Rohos Mini Drive, this error message pops up - , "There was an error opening this document. This file cannot be found.” The error is generated by Adobe Reader X wherein my current version is 10.1.2.
By the way, I have a Windows XP operating system and no problems were experienced on encrypting Microsoft Word files. This pdf error is so annoying! I desperately need your help.
Thanks!
Read more
I have MacOS 10.7.2 and blender 2.62 and 2.59 application. I can’t seem to export AWD file using blender with Armature scene.
Exporting without Armature scene just works fine. I need to do export with Armature. I’m having driver error:
ndof: 3Dx driver not found
found bundled python: /Users/sewonist/Downloads/blender-2.62release-OSX_10.6_x86_64/blender.app/Contents/MacOS/2.62/python
trying to save homefile at /Users/sewonist/Library/Application Support/Blender/2.62/config/startup.blend ok
{‘embed_textures’: True, ‘include_attr’: True, ‘include_materials’: True, ‘filepath’: ‘/Users/sewonist/Desktop/0001.awd’}
Creating mesh Cube
Checking materials for Cube
Found texture to create material?
Traceback (most recent call last):
File “/Users/sewonist/Downloads/blender-2.62release-OSX_10.6_x86_64/blender.app/Contents/MacOS/2.62/scripts/addons/io_awd/__init__.py”, line 62, in execute
exporter.export(context, **kwds)
File “/Users/sewonist/Downloads/blender-2.62release-OSX_10.6_x86_64/blender.app/Contents/MacOS/2.62/scripts/addons/io_awd/awd_export.py”, line 90, in export
self.extract_joint_weights(o)
Hello People,
We are having issues with DrawPlus application. This started on my mom’s PC, and now I’m having the same error on my computer.
It says something about document being corrupted when we save files. Please let me know.
See screenshot.
Thanks for all solutions.
DrawPlus
An unhandled exception occurred in DrawPlus. The document could now be corrupt, it is recommended that you do not overwrite any existing files when attempting to save.
Please re-start the application.
Read moreHi,
Does anyone know the commands to enable and disable the macros in X5? I can’t seem to remember where it is located. Macro options are grayed out and ALT+F11 key is not working as well.
I tried to uninstall and reinstall the application twice but macros are still disabled. I might be missing something.
Please help.
Thanks in advance.
Hello Friends,
I can’t open any .swf files from Photoshop. I’m getting several scan error in my event viewer. Is it possible that I’m affected by a virus? My FPROT antivirus can’t seem to fix the error I’m getting and I can’t see any related articles online.
Event Type: Information
Event Source: F-PROT Antivirus
Event Category: Scanner
Event ID: 4096
Date: 05/03/2012
Time: 10:16:30 AM
User: NT AUTHORITYSYSTEM
Computer: IT03
Description:
An unknown error occurred while scanning file C:Documents and SettingsAll UsersApplication DataAdobePhotoshop Elements10.0Localeen_usWorkflow PanelsmodulesPhotoStack.swf
