Archive
Who are know that microsoft work gift tag template and how we and other know more information for this gift tag?
Read moreKaspersky internet security 2010 is getting installed but not running?
Read moreDo you know how much people use the temi xp hitman 47 and how they use it their official or daily life?
Read moreHi.
I have updated Windows 7 (Ultimate) 32 bit OS. When I run any MS Office2010 application on any non-admin user, I’m getting errors such as “Microsoft Excel has stopped working”, “Microsoft Word has stopped working” etc. then the application will close.
And when I run as admin user I get “There was a problem sending the command to the program” error, but the application will launch after I hit OK, I have to manually open my files using the File button though.
I tried to change profiles, change the default printer from HP to MS XPS, I tried opening the applications...
Read moreHi experts,
How you and your other friends know about triton v7.1 and how you and your other friends use it your daily life?
Read more
Hi People,
Can someone please help me with my mail problem? I’ve just downloaded Zimbra with Outlook connector. I’m having synchronization issues and I can’t send and receive mails. Seems that I’m getting “This object does not have an ID, it is a newly created item”.
Please help.
Thank you for the help.
- - - - - - - ERROR 1 -- - - - - - - - - - -
Local Failures were detected. No action is required.
This e-mail was generated for technical support purposes.
Sync Type: Delta Sync
Store: Zimbra - FirstNameLastName
Computer Name: PC1
ZCO Version: 7.1.3.6347
Hello Friends,
I’m frequently getting QTCF.dll error whenever I launch my iTunes and JamVOX.
My applications work just fine, but this dll error keeps on popping up.
I tried to run a DLL fixer and also tried to manually register new dll files but error still persists. Does this mean my registry is corrupted? What should I do to get rid of this error?
Please enlighten me.
Thanks for all solutions.
RegSvr 32
The module “qtcf.dll” was loaded, but the entry-point DllReisterServer was not found.
Make sure that “qtf.dll” is a valid DLL or OCX file and then try again.
Read moreHi Experts,
Has anyone encountered insufficient privilege error on the final step of a software installation? I’m trying to install a trial version on my Windows 7 Ultimate (64-Bit) and verified that I have administrator privilege.
I tried to re-do the installation but got the same error.
Please help.
Thank you.
VectorScribe v1.2 for Adobe Illustrator CSS Setup
Service ’Nalperion Licensing Service’ (nfsx86cc) failed to start. Verify that you have sufficient privileges to start system services.
Read moreHello,
I’m getting a Programming Bulletproof Error 20007 error when trying to save my work.
I get this error when I input less than 10 lines then change default warehouse bin loc. Is this something to do with macros?
I’m not quite familiar with this error, see screenshot below:
Programming Bulletproof Error 2007
Current grid row 9 does not match its current memory array row 10/ this is probably caused by program or macro code changing the memory array current row, and not resetting it, or else not setting the current grid row to match it.
Read more
