Archive
I tried html emails before and the I want them to look nicer especially to my important clients.  I want to how to send html email with PHP, kindly include all the possible ways or applications needed by this. my OS is windows XP.
Read more
I want to know what are the advantages for using each type of dlna upnp over vpn network connections? and how to determine the best type for use in home network for smart devices like I-pad, personal computer and television?
Read more
As a test to the ZTE mobile I found the TV transmittal to be slow in some areas.
CDMA is the new GSM, why then would the ZTE CDMA speed be so slow?
Read more
What is the main difference of the wireless open key and the wireless shared key? I had been hearing this topic before and would want to know what are these, its function, and direction in selecting the best one.
Read more
I want to be able to view all the .prn files created in an Excel format. Where can I find the extension .prn to Excel converter online?
Read more
I want the image for graphic design, with different styles to enhance the letters independently and with words. I know a number of photo programs but none concentrate on letter art. Is there a photo program that caters for  alphabets using Unity 3D?
Read more
Now that flash is less used. I  want to use the javascript to create a banner that has a fade effect and I would like to know how to do it manually if possible. or if not where can I download a free javascript banner fade manual?
Read more
I want to download the game Logo Quiz, don't want to waste my online usage. Is it a good game? What do you know about Logo Quiz x2? Only respond if you've downloaded this yourself.
Read more
Sometimes my HP freezes when it's hot. For Sony Vaio laptop users the comparative is the fan. When Sony gets hot, to boost fan in Vaio what is/can be done? I don't want any excessive cost factor.
Read more
I had downloaded and installed the divx player yesterday. I had checked the directory folders of the program and decided to delete the folder named temporary downloaded files. Is this important? what is specifically the use of the divx player temporary files? and if it is, how to create that specific folder again that the program will read?
Read more
