Archive
Hi to everyone,
A problem with my codec for chrome download. I cannot play any music using Google Chrome internet browser online, I used to listen music over the internet but now it requires some codec. During the downloading process of the codec it gives me an error about compatibility. Is Google Chrome codec aren’t compatible with Windows Xp operating system?
Your suggestion is very much welcome.
Read more
How to possibly resize file in adobe writer? I am not familiar with that adobe writer it was just introduced by a friend of mine. I am hoping that some of you here know how to resize a specific file using adobe writer. If you will share with me your idea based on your experience it would be a great help.
Waiting for your support, thank you.
Read more
How to import image into access? Is there a way that a Microsoft Access database system will handle big images file? Would it possibly handle jpg, gif and png file formats? If there is some way that the ms access database can do so please let me know. Thank you.
Benjamin.
Read more
Hello friends,
How to create an annual calendar in outlook? Microsoft outlook application is just new to me; the company manager just trained me to this work and given a project of making an annual calendar report with important events for the year same as an organizer. How can I make this done using outlook software?
Thanks and Regards,
Read more
What are the .XML files uses with the user state migration tool in windows 7?
Read more
What is user state migration tool in windows 7? and purpose of the user state migration tool.
Read more
Hi techyv,
A problem with driver gamepad USB to win 7. How to check if the driver gamepad USB or joystick is properly installed in your computer? It seems like I cannot use the gamepad for some reasons, it wasn’t detected by the computer port. This is more on troubleshooting, I need your step by step instruction to be followed.
Hoping for your help and kind consideration.
Read more
What are the methods that I can use to transfer data with windows easy transfer?
Read more
What is Windows Easy transfer in Windows 7 and what is the purpose of Windows Easy transfer?
Read more
How to prepare a USB storage device as an installation source for Windows 7?
Read more
