Archive
Hello Brainy?
When I got my new phone, started research on it. I start to execute all the functionality in the phone. During the process when I try to sync the phone to my laptop to get software update, got stuck up with an update error message. Any help to solve this error? Anybody have same problem? Help please.
Error Image:
Words in the Error Image:
UPDATE ERROR
Update failed. Update for Windows Phone 7 (7.10.7720.68)
We weren’t able to update your phone. Please try again. After updating, you
might need to manually re-sync your pictures and other media.
We’re having some trouble...
Read moreHello tech guys, I followed the step by step instruction to sync my harmony touch remote. Sync is not connecting held up with a message, error occurred while collecting your devices and data. And I tried again by unplugging and connecting it but still the problem with sync exist. Resetting the remote will help? Help me resolve this issue.
Error Image:
Application Error
Error occurred while collecting your devices and Activities data.
Read moreHi Trouble shooters,
I got a new smartphone, crazy about it. I am with that always for the first few days of arrival. After some days I started getting this error message often. As of now phone is functioning good, main thing receiving call and able to connect online. But this error makes me irritating, whether I need to update my phone or the apps in the phone. Is this a common bug? Help me find out.
Error Image
ALERT
Sorry, we ran into a system error. Please try again later. If the problem persists,...
Read moreHi,
I am a dedicated Sprint customer for more than five years. Haven’t faced this error in the past, when I unplugged from the charging station and I attempt to browse or check my mails. Constantly I am getting this error message “Data call failure”. Anyone having same problem please share you experience. Recently I updated my phone to Optimus from basic model. Your help will be appreciated. If nothing works, planning to call customer service.
Error Image
Data Call Failure
Error Code 67.Registration failure. Your PCS Vision username and/or password may be incorrect. Please...
Read moreHello Pro,
I got an error message while I am opening an attached file in ArchiCAD. I checked the system requirements before installing the ArchiCAD. In the system requirements everything is perfect to this version. I am not able to find the cause for this error. Is any problem with the data? Whether I need to check the data validity? Pro’s give me some guidance.
Error Image
Error processing the ArchiCAD data
Error code=-2130312686
Read moreHello Experts, Being an oracle developer it’s very hard to handle such problems. I know this is very common thing but I have problem in that now. The problem is I am not able to connect the database with SQL, I tried again the same error is appearing. The database is locally located so I don’t need any permission to access. What will be the problem? Please explain it. Thanks.
Error Image:
Error encountered
An error was encountered performing the requested operation:
Listener refused the connection with the following error: ORA-12505, TNS:listener does not currently...
Read moreHello Whiz,
I always work in and around Wordpress that’s my nature of work. Now I am going through a tedious problem, I am not able to upload an image file or video file and publish it. Somewhere it’s going wrong, may be file size, corrupted image or the filename. Whizzes please help me to resolve my problem.
Error Image
Post edited
Post edited successfully, but an error was encountered when uploading media:XMLRPC Fault: Could not write file wpid-VIDEO0246.3gp (Invalid file type) [code 500]
Read moreHi there,
I ended up with an error message when I am trying to uninstall Autodesk design. I don’t need this anymore, but I couldn’t do it. Why it’s not allowing me to uninstall? Is any problem with registry? And also help me to edit the registry file. Is it good to edit without backing up the data? Experts in this field help me to solve this problem.
Image of the Error
Error Message in the Image
Autodesk Revit Architecture 2012
Error 1905.ModuleC:Program Files(x86)AutodeskAutodesk Design ReviewECompositeTextSearch.dll failed to unregister. HRESULT -2147220472. Contact your support personnel.
Read moreHello Ally,
When I accidentally uninstalled the Autodesk 3Ds Max 2013 and then I try to install in again. But I think I have not done that perfectly. When I start the installation, I am getting an error message to check out license. How to check the license? How it can be fixed? Struggling hard to find the error, help me fix the problem.
Image of the Error
Autodesk 3ds Max 2013
The software license check out failed.
Error 5
Read moreHi pro,
Not able to locate the error, where I made mistake in installation. I installed using the SRCDS content manager.exe. I try to fix the issue by renaming the ‘dll’ file and also tried by deleting it, but nothing happened. After some research I also closed the steam, still error pop up. Need professional assistance.
The procedure entry point ?Lock@CThreadFastMutex@@ACEXII@Zcould not be located in the dynamic link library tier0_s.dll
Read more
