Archive
Hi there,
Friends, I am a good gamer, I have lot of different game types. Last night I download the Sims 3 game version, when I try to startup I am facing some problem. Means I am unable to start the game. Anything went wrong while installation? How to setup this game? Assist me solve this problem, help please.
Unable to start game
service initialization failed (0x0175dcbb)
Read moreHi all,
When I try to play a video in Camtasia studio, I got ended up with an error message. This means Camtasia studio not able to decode my video to read frames out of it. Thought this will be of this particular video, so tried with other videos too. Nothing happened error remains the same. What do I do now to solve this error? Hunting for solutions please help me.
We’re sorry! An error has occurred with the following clip on the timeline: C:UsersThomasDownloadshl220130619 225553161.avi
Camtasia studio cannot complete the production of this project.
Read moreHi brainy,
When I update the Adobe After effects cc version with the latest one, it went well to some extent. The problem appeared with the message, you can’t use this version ‘Adobe After effects cc’ with this version of OS X. Am I updating wrong version? Anything else is missing in the update? Enrich me with some ideas. Your help would be great.
You can't use this version of the application 'Adobe After Effects CC' with this version of OS X. You have 'Adobe After Effects CC' 12.0.
Read moreHello whiz,
I am getting this error in FL Studio, if I click ok button, applications stop running. I don’t have option to close, so I used the regular method of using Task Manager to kill the process. How do I solve this error? Can I use it in sandboxie, work better? Help me sort the problem. Thanks.
Access violation at address 0690B0E0 in module ‘Alchemy.dll’. Read of address FFFFFFFC.
Read moreHi friends,
GTA download and installation went successful but when I try to launch it for the first time, I got stuck up with this error. For your information I launched the game with asi and also with shaders. Error appeared when I loaded the game? Anything went wrong with Deferred.fx? In what way I can solve this problem? Your help is great.
CDeferredRendering::Setup : D3DXCreateEffectFromFile() – failed while compiling deferred.fx
Read moreHi Experts,
I was working in project in Vegas Pro for a while, time came to upgrade the version to Vegas Pro 9.0. We did the update and it went pretty well and good without any issue. After updating when I try to open the existing project I ended up with this error message. I guess any problem with updating? Help please.
An error occurred while loading the project file Twentyfour.veg. The COM object failed to initialize.
Read moreHello tech folks,
I have a problem with Aria Player engine whenever I try to add an instrument from instant orchestra. With my knowledge I found that this error might be with Aria Play engine. Should I need to run any update? Update will not create any different issue? What is Garritan Harps? This is frustrating help me to solve this problem.
slot 0:
ARIA cannot find”Notation/7. Solo Strings/2. Viola/n-Viola Solo KS”.from product:2000
Read moreHi all,
I was disturbed often while playing a game interlude, I love this game. So I used to save the game to continue in future. But today when I try to save it triggered me an error message saying it could not save. Before I used to save but now I could not, why? Did anything go wrong? Any guess? Help please.
Could not save as “Interlude” because out_of_range: Cmn_PolyVectormpl::At while translatingPaths.
Read moreHello Professionals,
In work I use this Media coder to encode the audio and video transcoder. After this error message I found out that the path to Cuda encoder is not correct, but when I click ok button the program stop working. How will I correct the path? Is everything ok with my version? Help please.
CUDA h.264 encoder is not included in this distribution.
Read moreHi all,
Friends I think there is a bug in Adobe Acrobat reader. I got a PDF file in my mail, when I opened it triggered an error message. To my surprise there is no message in the box, empty dialog box with ok button. When I click it close the program too. What happened to Adobe reader? Any bug? Help me fix this bug? Thanks for your help.
Read more
