Archive
Hi friends, when I try to install and launch VMware workstation, I ended up with an error. When I am in the setup procedure got an error message to see the log file then it stopped running. Any issue with the log file or missing any log file? I am in the middle of all my work, how do I solve this error? Your help would be great. Thanks.
Unable to build kernel module.
see log file /tmp/vmware-root/setup-24056.log for details.
Read more
Hello All,
I have a problem in LibreOffice 3.6 installation at my work place. We have like five systems in a network, when I try to install libreoffice 3.6 it is throwing me error. Only one system is upgrading to LibreOffice 3.6 and I have the old version too. What might be the problem? I cannot keep both versions? Help is appreciated.
Please exit LibreOffice 3.3 and the LibreOffice 3.3 Quickstarter before you continue. If you are using a multi-user system, also make sure that no other user has LibreOffice 3.3 open.
Read more
Hi whiz,
After completing some jobs in Finale, I am getting this error. This error is not affecting the files or creating any problem. But still why I am getting this error? Till now ignoring this error, what should I do to stop this error appearing? After a search in goggle I deleted some Finale temp files. Is it a bug in Finale? Please help to find a solution.
Ctree error 55 in CTVNOTE:283
Read more
Hi Whiz,
I am not even aware whether I have java in my system and I never worked in that before. But getting some javascript application error in my system, how this is possible? After some research thinking of some add-on might be creating some problem? Whizzes’ associate me to resolve this error.
3
Read more
Hi tech savvy,
I have Mac OS X Lion operating system with 64 bit and I installed this Many cam latest version. I downloaded this version from the licensed website. But when I try to connect to Studio webcam the real problem triggers. How do I stop this error? How do I solve this? No application or program is using this manycam. Help please.
ManyCam can't connect to your Microsoft LifeCam Studio webcam.
Please make sure this device is not currently used in another application.
Read more
Hi Ally,
Accidentally Operating system is crashed in my Dell laptop; I try to re-install the OS using the CD which came with the laptop. I did not have backup for any of files. Do all my data will be deleted? Can I retrieve my data in any way? One more question please, Recovery and installation CD they are different? Urgent help please.
This software can only be installed on a DELL,Unbranded system
Read more
Hello Corel Experts,
Experts I am just a beginner in CorelDraw, having hard time now. I installed the trial version last week; it went pretty well and good. Even I started working in that, the problem is, I am getting an odd message when I try to export files to CorelDraw. What is the cause for this problem? We cannot do this in trial version? Give me some solutions, thanks.
Converter not found.
Read more
When I try to run the Java application I get this error often, it’s little bit irritating me. I have window 8 operating system, it’s a personal computer I am the administrator. So I think I have full access and permission to execute all type of files. What will be the problem? Not able to think out of box, help please.
Configuration file cannot be written.
Read more
Hello whiz,
I like to take pictures and videos a lot, it is my passion. When I try to open it in my computer using Quick Time player I got stuck up with an unknown error message. For your information the video I took is from high definition camera Nikon d5100. How to solve this error? All my videos are generating the same error. Please guide me to solution.
error -108: an unknown error occurred
Read more
Hi Pro,
I am all time winamp user, whenever I start my system first thing will be opening the winamp. Yesterday I faced an error message while trying to play a song in winamp. In the past I never experienced this type of error in winamp. Any problem in winamp, do I need to re-install? Whether it is asking for an update? Please make me clear. Thanks.
Error creating DrirectSound buffer.
Error code: 80070057
Read more
