Archive
What and when it is required to update BIOS? What tools are required for BIOS Updating?  What types of improvements we view after updating BIOS? Is this possible to set boot from USB Flash Memory as first Boot device in a motherboard after BIOS update which doesn’t have this Feature?
Read more
How can I show a custom logo on Boot screen (my organization’s logo on PC startup boot screen), It is normally Motherboard Manufacturers Logo. Please Help me in following Points:-
1. What is the process for show custom logo at startup?
2. Is this legally valid to change this logo?
3. What size (dimensions and Size in KB) of image we can use in this logo?
4. What type of image (JPEG/GIF/BMP/PNG) can be shown in this Place?
5. By Changing this picture is its effects on warrantee or working of the motherboard?
6. What tools or Software required for this?
Read more
I tried using windows mapping service but it didn't mount the network drives that I needed.  Working if I use Win32 forms.  It seems like Windows put it in another environment. I allowed the service to interact with the desktop and still no mounting.  Is this a security issue?
Read more
I am a Mac OS X user. After installing OS X, I get a catastrophic hard-drive crash that requires me to initialize or replace my boot drive. The event selection didn't appear in proper place for lion calendar task. Can anyone help me how I will create and manage lion calendar task on Mac OS X?
Read more
I want to buy S2 Galaxy. But I want to know about the camera capture?Is the White Eye editing can edit to remove Red Eye?
Read more
I am trying to access source-controlled documents in our office. Our office uses Apache SVN servers with searchpoint as the search platform.
It's kind of confusing because usually I just create an HTML access point so that the xml-xsl would be converted.
But in sharepoint, I think you have to create an index.html file which to me takes up a lot of time.
Does anyone know an easier way to sharepoint search svn servers?
Thanks in advance
Read more
My old OCR program stopped working for some reasons and I need to have the best going aside from Adobe Professional. Do you have any suggestion? I need to scan to pdf and edit the document.
Read more
I have a Samsung S3 smartphone with Ice Cream Sandwich version.  I'm planning to install the xp media center app for android so I can access my media files(mainly large divx files) in my home pc when I need them when I'm at work.  Will I have to update my android version?  Will the Xp media center app for android work without wifi? My office does not have a wireless router so I'd probably have to use my 3G signal.
Read more
Hello, I’ve been using QuickBooks 2005 trial Australia and not ready to upgrade to other versions. I need to reactivate the same version but I’ve lost the registration key already. I want to make sure that the files I’m importing will not crash so I need the same to be reactivated.
Read more
Is this possible? I'm planning to sub-partition my extended partition.  And if it is possible, can I assign additional drive letters for each sub-partition?  I hope it would not reduce disk performance.  Need opinions on turning tables partition.
Read more
