Archive
Hello Webmasters,
It is not easy to understand the enterprise vocabulary Joomla's forums use by these days, so my query would be : is there any steps that you -experts- may advise me to follow in order to get some experience in Joomla CMS development ?
Thanks a lot.
Read more
Hello Tech's,
Could anyone explain me how to extract sid file from a package in case I would want to mount the image from the package ?
Seems that it requires a special software in order to get the file.
Thank you all.
Read more
Hello IT Experts,
May I customize my old Antivirus by adding the latest avg 2012 skins ?
If yes, may you please explain me how ?
Thank you for the help.
Read more
Hello Experts,
Is there a possibility for the PC Backup Agent to make an auto backup on logoff Windows 7, so the user would not have to request a backup manually.
Thank all.
Read more
Hello Flashers,
Is it possible to make flash cs5 create component that are not part from the known shapes ? for example parallelogram and triangle.
I do not want to make it manually by assembling lines, instead I am looking for a method allowing to do so automatically, I would only have to specify the base of any shape.
Read more
Hi all,
I would like to get more details about Wordpress, is it convincing ? Does it have a good support community ? experts are them satisfied about such a product ? in short I am getting an idea on all about wordpress website design, I would know if it is the blog designer I should adopt.
Thank you guys.
Read more
Hello guys,
May you please help me find out the free DirectX for warcraft ?
My Laptop specifications are :
Processor : Intel i5
Memory : 8G
I assume that my graphic processor would require something precise.
Thank you very much.
Read more
Hello guys,
May anyone help with finding a way to make the design, the quality and the form of ribbons managed by software? I have already seen some machine doing this, but I may assume they are expensive, right?
I would also ask you to only provide me with the free ribbon print software please.
Read more
Hi Experts!
Far as I know Windows has multiple desktop gadgets but none is capable of showing internet bandwidth consumption.
Is there any way to get a nice gauge to measure internet use and show it on my desktop ?
Read more
Hi Techy`s,
Could someone help me find an Ajax slider price calculator module for Joomla ?
May you also explain how to install it and what are the prerequisites for it to work smoothly.
Thanks a lot.
Read more
