Archive
Hi guys,
My question focuses on how to generate a security key using the aes256 file tool, I also would like to know if it is possible to crypt any file with such a tool.
Are there any restrictions with respect to different operating system ?
Thank you.
Hi Developers,
I want to know if I can use a PostgreSQL 8.3 database to make a Blackberry application, I just need to know how to install blackberry connect jar for Postgre, please tell me also which drivers will I need to import.
Read moreHi experts, Where can I find IMEI code iPhone checker free Software ? My aim is to avoid getting a locked SIM after the standard number of tries (usually 3) Thank you very much.
Read moreHi Tech's, My question is pretty simple : is it possible to convert m4a header iTunes fix Nokia phone and play it on such a device ? In other words : how to enjoy playing m4a files on Nokia Phone (Symbian OS, not Windows mobile) Many thanks.
Read moreHello Apple lovers,
Read more
Hi
I am interested in downloading BPM 64 Bit free. I am using Mac OS X version 10.5. Please share the information if anyone has any idea about this.
Read moreHello geeks, Is it possible in to program a menu login jquery based ? The challenge would be to integrate it into a site that contains no JavaScript code. Knowing that JQuery requires all its library to be loaded, do you think my scenario is realistic ? Thanks a lot
Read more
Hello folks,
I want to know how to create a download manager using VB6 which also shows the progress bar, time and speed.
If anyone of you is having the source code, just share it with me or tell me some tutorials, which can help me develop this program.
Please make it fast because I have to submit VB6 create a download manager in four days.
Thanks!
Read more
Hi guys,
I would like to get your opinion on the optical character recognition feature that is being developed currently, would the OCR Pixel clear be as good as the real clearness? And when will this technology be available on Webcams?
Read more
