Archive
When we purchase any HDD, memory card or USB flash drive etc. It shows less space than its printed capacity. What is the actual reason behind this? Ex.:- a 500 GB capacity HDD only shows 465.75 GB. Where are other 34.75 GB? If we check flash drive shows less space than printed capacity. Same thing happened with other storage media. I want to know its actual reason. Please reply if you know.
Read more
I'm trying to create a compilation of music videos in an m2v format with a permanent logo on it. The videos are in MPEG format so I'll probably need a converter. I'm planning to use Super video converter with logo maker. What is the easiest way on how to create an m2v logo using the said converter?
Read more
I'm having trouble regarding my font size. Is there any option wherein I can change the font size in Eclipse idea printing? Trying to print some codes using CUPS and the fonts are just enormous, with no option to lower the size of the fonts.
Read more
Hello, Wii Backup Manager used to be the best wbfs manager 2011 for me because it works perfectly, until it gives me these errors:
split 0: size (-1) not sector (512) aligned wbfs
error: hd num sector doesn't match
Does anybody know how to fix it?
Thanks,
Sargent Franks
Read more
Hi Experts,
I want to know the details of software dealing with Investigatory Project Ideas. Does it provide a template or it creates ideas from case to case basis? Where can I find it for Windows 7.
Read more
Hi everyone.  My friend recently gave me the Showtime expansion pack for Sims 3 which has the Katy Perry Collector's Edition.  Any suggestions on where I can download the free core game of the Sims 3.  I run on windows xp, 32-bit, sp2.  The problem is, it requires service pack 3 and I only have service pack 2.   What kind of glitches would I experience if I download sims 3 free xp 32 bit sp3?
Read more
Hi Experts,
I have heard about a software which repairs JPEG files. Is it true?
I am in desperate need of Freeware Repair JPEG File.
Furthermore, I would appreciate if somebody helps me in steps to use it.
For your information I am using Windows 7.
Read more
I am interested to install wood sign Photoshop brushes in my MacBook running Mac OS X 10.5.6.
Help me to find out the high resolution wood sign brushes.
I shall be thankful if anyone writes step by step process (with images help) of how to install them.
Read more
I'm trying to find the best web video Downloader in terms of user interface and reliability. Another plus is, when downloading, in what format would it be?
From what I've read from some websites, Google has packaged Chrome with a flash video player while Firefox has the advantage to have add-ons and plug-ins. Which do you think is better over-all, Chrome web video Downloader 2011 or Mozilla Firefox?
Read more
Hi Experts,
I own HP 32GB Touchpad tablet running WebOS 3.0. I am fond of playing Spider Solitaire but couldn’t find one for my tablet that runs on full screen. Can anyone help me buy/download Spider Solitaire for a HP Tablet? Please share at earliest.
Read more
