Archive
I am looking for a Mac software on an Internet that can direct record audio? Looking for a free software. thanks
Read more
I am having problem with my Mac OSX Lion, when i record audio on my Mac OSX,
I cannot export an mp3 file format, anybody can help?
Read more
Hello Techyv,
My colleague sent me an email with files that need to be translated, but Babylon can t translate pdf files.
The only thing I did recently was to update my anti-virus software and restart my computer; I have also made sure that adobe reader works with Babylon as I have worked on a document last night.
What should I do?
Read more
How may I add the CrazyTalkCam suite to the usb web cam genius pictures model number FaceCam3000.
I would like someone to help me install it and synchronize it with the Cam.
Possible ?
Read more
Hi Techyv's,
Is there a VBulletin forum manager software that may help me compare pages from different sites?
For example as making statistics and compare article content or user activity between multiple VB sites.
Thank you so much.
Read more
I have got an error while enter code in stick run of multiplayer functionality. While debugging a code it shows me a blank screen for a moment then nothing happened. Please tell me how solve this problem ?
Read more
I am trying to play cda file in cellphone the various multimedia players are not supported .cda file extension. Will you please tell me that how to play cda file in cellphone? Is there any application or tool to run on it?
Read more
I am trying to download Zune software for me to be able to sync my Nokia Lumia 910. However, upon the installation, I received the error code  0x80070643. Is there anything special that I need to do to be able to install Zune? Thank you.
Read more
I think we can VB6 barcode convert using "Text Box" function, Can any one guide me or explain on, How it need to be done.
Read more
I have a new fresh net book. I think it needs to new set up. I can not do this as this has no CD drive. I am in troublesome.
What can I do in this position? Will any one help me to do that?
Read more
