Archive
Is there a way to retrieve Vaio blu ray driver after having deleted it by accident ?
Maybe it depends on the physical machine, especially the motherboard, besides the blu ray reader itself.
Where may I find the specifications of my driver on my computer ?
Read moreI m trying to find out why SSL VPN on mac OS stops working, there are also some issues regarding the configuration of SSL VPN on mac OS.
Can anyone tell how to solve this problem and make SSL VPN work on mac OS?
Read moreI need help regarding the scroller of the touchpad of my laptop; it gets unresponsive sometimes and sometimes it simply stops working. I doubt that there is an issue in the touchpad driver, please tell me which driver should I download to fix the problem?
Read moreI have couple of msn accounts, on one account I have simple emoticons while on the other I have purchased and custom emoticons. is there any way to transfer msn emoticons from one account to another?
Read moreHi Experts,
I own MacBook Pro 2.6 GHz and want to install Adobe Flex 4 Paint. I have downloaded it from a website unzipped it. Now there are different directories in the unzipped folder. I don’t understand what to do next for installation. Please help me how should I install. Can anyone tell me that does Flex 4 have any compatibility issue with Mac?
Read more
Hello Everyone,
Recently I wanted to switch on my PC. My system boots with beep tone but nothing appears on the screen.
After that I tried to clean up my CPU and I cleared all the dust on motherboard and checked all connections are OK.
Clearing the graphics card I resolved my issue. But this time after about 20 minutes I heard from my CPU continuous beeping and my monitor became darken.
My PC is running smoothly but there is still continuous beep tone and my monitor light is very low. I tasted my monitor. There is no problem. What can I do...
Read moreThe Nokia 5800 phone I have got has GPS navigation. I wish to use it as my traffic assistant, for which I need to activate 5800 gps talking option. How do I make use of voice assisted navigation when the phone is used in GPS mode.
Read moreI need help regarding printer files, is there any way of converting printer files to Excel (2003, 2007,2010) file format? Can this be done by using "Convert XLS" software?
Read more
How to figure out the problem in Acronis bootable media while connecting with Dell Network? How to connect Dell Network with Acronis while having no problems?
Read moreHi Guys, I’ve downloaded Zip repair online for fixing zip file on mac but it doesn’t seem to work. I can’t extract the files yet. When I access the file I’m getting the “unable to unarchive…” error message. I’ve tried a few software kits already and they are not effective, I need another option to work on this quickly. Please help!
Read more
