Archive
I don’ t have any key store or key file for that certificates. Is it possible to use an already existing certificate in Mac web server? Even if I have a key file also, is it possible to use that SSL certificate?
Thank you
Read moreHi experts,
One of my friends is a great fan of FIFA. He is playing FIFA Manager 2012 since the day it touched the market. He is now fed up of playing games on same stadiums. I shall be grateful if any one can tell me whether new FIFA Manager 12 Stadium Files can be installed? If it is possible, please tell me the location where I can buy/download these files. And in the end, how can we install them?
Read moreHi,
I am fond of listening music during my work. And prefer to play live DNS streaming radio.
I have got new PC with Windows XP in it.
Every thing is working smoothly including the internet but whenever I try to play live radio, it shows an error “Internet testing failed, cannot connect with server ".
Please help me resolve this problem.
Read more
Hello techyv Experts,
I am looking out for piano applications for my ipad via which i can learn to play piano and even record or sing to my compositions.please list down the top 10 piano sound applications which are user friendly and easy to use.
Folks,make sure the apps do support full MIDI import and export capabilities with studio quality presets
If,you can also provide top 10 amazing piano sounds that will be an add-on.
Read more
Hi all,
Who knows a Winamp plugin music sample tester ? some voice file formats require the sample to be of a certain quality (high definition for example)
Thank you for your help.
Read more
I am a user of Windows XP and want to apply the custom Mp3 Folder Art Templates. Some of my friend talked about Query Templates to complete the task. I need expert’s help to install these templates. I mean where can I get them from? What applications and tools are needed? I would be grateful if you write down the full step-by-step process to install.
Read moreHi,
Could anyone help with finding the best wifi network monitor software available for the following Access Points and Wireless controllers :
Cisco, H3C, 3Com, Colubris
I do know that sometimes a single management Software can do the job perfectly, but I would like to know the one which fits my needs depending on the material I am using in each situation.
Read more
On my Windows system I was using VMware disk mount appeaser utility to mount a VMware virtual disk (.vmdk file). In past I was able to read, write and modify disk. But now I am facing a problem with it. Actually I mounted the virtual disk with snapshots. Unfortunately I make changes in snapshot and now my disk is lost. I am searching for the way to get it back. Can I get back my disk? If you know this then tell me how to do.
Read more
I am searching for HD Videos of Iran. Can I download video hd Iran from any website? If you have already done this, then please inform me about website links.
Thanks
I need to know if it is possible to improve my webcam capabilities by adding new functionalities such as : facial recognition, iris scan, logon, knowing that mine is a Toshiba embedded in the PC.
Read more
