Archive
Hi TechyV,
How do you explain what happens whenever I upload a JPG file to my website control panel, it converts into a .txt or TEXT file automatically? Due to this, the file becomes useless and thus can't be viewed as an image.
I've searched for several remedies including making sure that my binary transfer options/converter settings are in place that is not the issue; my server is doing okay as well. I just want to know the detailed technical reasons why the file converts by itself.
Thank you.
Monaliza
Read moreHi,
I have ZTE R100 mobile with java support and other default applications installed.But it does not have any software which can read ebooks on my cell.Please somebody tell me where to get a book reader zte r100 for my phone,so that i can read ebooks.
Read moreI am making a MSN chat bot and I want to add voice chat to our rooms only, So members can voice in each room. I want to connect directly the member to voice server when members enters the room. I am unable to find sample script. Kindly tell me If you know how to do write msn chat room bot scripts please.
Thanks
Read moreHi TechV, How do you explain what happens whenever I upload a JPG file to my website control panel, it converts into a .txt or TEXT file? Due to this, the file becomes useless and thus can't be viewed as an image. I've searched for several remedies including making sure that my binary transfer options/converter settings are in place--that is not the issue; my server is doing okay as well. I just want to know the detailed technical reasons why the file converts by itself.
Read moreHi Techyv,
I wonder why sending large email lists is not allowed on Outlook, I am an avid user of this Software, and everytime I try to send an email to a pretty big list of contact all of my friends for example, that are more than 70 I am unable to deliver the message.
Is there any option to modify in order to change this ?
Read moreHi,
My flash plug in browser was running perfectly in my Android. I have recently updated my android device to Android 4.x. But now flash player is not working it does not load flash content. Please tell me how to fix the flash plugin browser android problem.
thanks
Read moreI am using windows 7 and I want to install bit defender total security. I purchased the CD from the shop. But I am facing a problem “bitdefender 1500 error” that whenever I Tried to install it an error message occurs: "Error 1500. Another installation is already in progress. Complete that install before proceeding with this installation."
Please tell me is there problem in BitDefender or Installer? While my other installation is normal.
Read moreHey,
I currently own an Nokia E71 and an Android based phone, all my old contacts are on the Nokia.
Does some one know how to convert all my old contacts from my Nokia to the Android phone?
Read more
I am using Window 7 on my computer. I have downloaded Avid Quick Time Codec LE 2.3.8 from the internet. I am wondering how to install it, because it is not zip or exe file.
Please tell me avid codec le is the corrupted file? I think may I have incorrect installer Or there is a compilation problem with installer? I don’t know what the problem please helps me out.
Read moreIs there a safe place I can save my documents other than my computer?
Read more
