Archive
I am looking for android alarm clock available with open source. If you know any good open source clock with custom features available, please inform me, I shall be very thanking full to you.
Read moreHello, I have just bought my self an HTC HD2 full sense 4 but I have failed to access the games. Does anyone know where the games menu is located?
Read moreHello Expert,
I have created many 3d models in *.max format. I am searching for free 3d max conversion software to convert my models. Tell me If you know about some free and easily available software with full features. It should convert Basic structure like *.3d or *.obj.
Thanks
Read moreHi Everyone,
Now I am in a serious problem. When I want to browse from my PC, my PC became hang and a report show that, "DrWatson Postmortem Debugger" has encountered a problem and need to close etc.
I am using Norton Internet Security with 1 year subscription. I think my PC is infected and Norton can not delete them.
I also tried Kaspersky but No result.
In this situation what can I do.
Wali
Read more
Is it Possible to Record output sounds from Videos, Games and other applications without Connecting Additional Devices to my Mac. I want to use any utility for internal sound recording on Mac. It is similar to windows application "Cam studio".
Read moreHi Experts,
I have a problem with my Google Chrome regarding Java plugin. Whenever there is Java-specific website, there will be a popup stating 'Java(TM) was blocked because it is out of date' and need to update Java Plugin. However, I already did updated it but the problem is still there. When I click on the 'Update Plug-in' button, it directed me to the Java download page which is the same page where I update the Java beforehand. Please help me on this issue.
Thank you.
Does Apple need to change their design and upgrade specs to match Samsung's much cheaper smartphones? Can Apple stop the Samsung juggernaut?
What new ideas and design should Apple create to stop the Samsung juggernaut? Should Apple be attempting at a new design and worry about the much bigger specs and functions of Samsung smartphones?
Read moreHi,
I want to create some sequence of modal dialogues using Javascript technique. Some of friend suggested me to use Ajax Pop-up box. Can any one help Ajax download popup for Mac OS. In addition to that can one tell if it is helpful as I want to avoid page reloads.
Read moreHello,
I'm looking for a list of cleaning utilities. I need a few shareware and freeware utilities so I can test them out and review them.
I own a laptop Acer 7750G with a processor Core i7 2630QM and Windows 8 in it. My laptop attains extra temperature while playing few heavy games which makes me shut it down for some time. I have heard about cooling utiltiies. Can any one help me having Acer Cooling Utility and brief me how to use it. So that I can play un-interrupted games.
Read more
