Archive
Hi Experts,
I need help to prevent my data to be damaged. Please tell me how to remove bad sectors on flash drive. These bad sectors are spoiling my valuable data.
Read moreHi Experts,
Can any one describe the proper differences of Winrar vs and 64. I have heard a lot about both these software but i cannot explain the better differences. There are a lot of versions available in market but i just want to know that what is the difference of 32 bit version and 64 bit version.
Read moreHi,
When trying to transfer video from linux to ipad 2 is it normal to experience traffic latency and delay ?
May you please advise on such an issue ?
Read more
Hi all,
Everybody knows the famous beautiful XP wallpapers, unfortunately the documentation reports that Logon Screen needs Windows 7 as a minimum required OS, but, what about if I would want to tune my wallpapers for another OS version ?
Is it possible to tune up logon wallpaper XP for previous Windows Systems ?
Read more
I would like to make my windows 7 desktop themes unique, obviously the best way would be to create my own theme, and personalize my wallpaper, the window border, the colors.. but is this feasible ?
Read moreHi,
I have read that in order to get the free vpn on demand iphone feature work I must generate and install an authentication certificate.
Due to the complexity of such an operation I turned to you looking for advices regarding the easiest way to make vpn work on the Iphone.
Thanks in advance.
Read moreHi everyone
I am using iPod and I want to change some tools and panels installed by apple like iPod front panel assembly. After a long effort I could not separate front panel with LCD because looked covered with glue please give me helpful suggestion how to separate the front panel with LCD.
Thanks in advance
Read moreRecently I saw a link which says: IPOD 13 DOWNLOAD WINDOWS. I clicked on the link and an exe file downloaded. I thought that its a software update for IPOD which can be installed from windows.
To cut a long story short I installed the software and then restart the PC, after reboot the system become so slow that it took ages minute to open my computer and also I couldn't find the installed software.
It’s some kind of virus which I intentionally installed on my system, what kind of an idiot I am
Please Help ME!
You people are my last hope.
Read moreHello,
Is there any foxit pdf editor mac compatible version ?
The Windows version looks great, and -most important- is free, but is there any alternative to the pdf commercial editors for mac ?
Thank you so much.
Read more
