Archive
With the V Sequencer, I have made an App-V package of Adobe Photoshop CS5. Following a couple of advices as mentioned in google search, I was successful in the sequencing. But it was a lengthy one. Then I imported the .sprj file into that ‘Application Virtualization Management Console’.
After that I started to have Refresh in the Server in the ‘Application Virtualization Client’. But my such an attempt has been repeatedly rejected. I was shown the following message.
The error was very common and its code was 4615186-19D0810A-10000005. As I proceeded it appeared,
Application Virtualization Error
The...
Read moreDear readers, while running Photoshop, I got the following error message.
I was running the program on a cloned drive.
Sorry, a serious error has been detected.
To continue using Adobe Creative Suite, please reinstall the application.
I reinstalled the program and authorized it. Later as I tried to open an image file I got the above message.
Please help.
Read moreHi to everyone,
Why were my widget Blackberry is slow? I just received a gift from a friend, a Blackberry Bold 9900 series. I am having a problem with its widget for it becomes slower and slower when moved. Would you mind to give me some idea to resolve this matter?
Your suggestion is very much welcome.
Read moreIn my Adobe Photoshop CS3 I often get the following message that deprives me of my desired action done. Is there any solution? Please give at least one if any.
Adobe Photoshop CS3 Extended
Could not complete the command because of a program error.
Read moreI am using a primary pc which runs on 64-bit Windows 7. But I failed to run the installed 64-bit (x64) version of Adobe Photoshop CS5 on it. It often does not run accurately or sometimes it even failed to be started.
It also happened the same in Vista or XP OS that I use in my office. In all those pcs it often showed the hereby attached error message saying
The application was unable to start correctly (0xc000007b).” Click OK to close the application.
How to solve this?
Any idea, please?
Read moreOne of my PCs is running on Windows Server 2008 x64 SP1.
I failed to install any Adobe CS4 software on it. Why?
Do you know?
Please help.
I tried to install the trial pack and got the following error message.
Installation of the following components has failed:
Last night I got Crossover Office installed on my SUSE 10.2.
Since then whenever I tried to run Adobe Photoshop CS 2, I am getting an error.
The error screenshot is attached here.
You are not allowed to continue because your account does not have the proper privileges.
Please log in using an account with administrator privileges and try again.
Any idea will be highly appreciated.
Please ASAP.
Read moreDoes Debian need Defragmentation, If so please help me to find free Debian Defrag tool or send me the download link
Read moreHello Friends, I want an offline Microsoft Access SQL Syntax Checker, that will display any errors found in the syntax
Read moreI want to download a Piano Flash navigation for free of cost, please help me to find a better Piano
Read more
