Archive
I have installed Topaz 2012 CS6 Plug-in in CS6 but is not shown up in CS6,
Please let me know, what may be the reason and get me a solution ASAP.
Thanks in Advance.
Read moreI want to have an antivirus app for my Android device but first, I want to know if it will consume too much battery and memory size. If its not, what are the best antivirus software for my Android phone? Thanks.
Read morePresently I am using the application ‘Photoshop CS5’ for my different picture related activities. It has been okay for the last few months. Today morn, as I opened the application as usual, I got the following error whose code is ‘Error 16’ along with another error dialog box.
Hello Readers!
A problem has occurred with the licensing of the product. Restart your computer and re-launch the product.
If the problem still occurs after restarting, contact customer Support for further assistance, and mention the error code shown at the bottom of the screen. Error: 213:10
https://helpx.adobe.com/support.html
Please help me to solve this problem.
Read more
Hi Readers!
As I migrated from my IE 7 to IE 8, I faced a critical problem. It happened on my primary desktop. My primary desktop runs on Windows Server 2008 x64 SP 1.
I got the upgrade done too quickly without any trouble. In the beginning I thought it was okay.
But for the first time when I started IE 8 and started navigating to a website, I got the following error message which says,
Hello everyone here,
Today I am here with a critical problem. In my Gmer I am facing the following error, It took at the time of the application’s getting started.
It also occurred while scanning and even in safe mode.
Here is the error message.
GMER
C:Windowssystem32configsystem: The system cannot find the file specified.
Any idea? Please help.
Read moreHello Viewers,
Have you ever faced the hereby attached error?
I am totally fed up with it. I need to fix it up?
Do you have any suggestion for me?
The following Z drive is a folder of a mapped network.
The process cannot access the file ‘Z1.Multimedia2.MoviesActionKill.Bill.Vol.2.2004.avi.tgmd’ because it is being used by another process.
Please help.
Read moreIn my "ImgBurn" whenever I attempted to burn any DVD, I got the hereby attached error message.
As I moved forward by pressing ‘YES’, the DVD got burnt.
But, the burnt DVD can’t play any audio on SET TOP players although they can be easily played on laptops.
Unable to find any cells that could be used for the layer break!
Now would be a good time to start crying, because technically, this is the end of the world.
The layer break must be between sectors 405998 and 2086912.
Sector 405998 falls within VTS_0 1 (title), which starts at sector 348.
Relative to...
Read moreI have a file which I can play with ‘Windows Media Player’. I want to convert this file so that I can play it with Premiere 6.5 AVI files. Whenever I tried to play the file in Premiere, I got the hereby shown message,
Unable to open that file.
File uses an unsupported compression format.
File path: D:AVI2007_10070139.AVI
What I should do now? Please help.
Read moreDear friends,
For the last few days I am getting the following error message.
As I am a new user, I can’t make out what to do. Here goes the screenshot of the error message.
Error
Error reading from file E:dataGame80845C2AC488A571Objects.pak. Verify that the file exists and that you can access it.
Please help me.
Read more
