Archive
Hi Tech professionals,
When I am in the process of installing the NI software, I got a peculiar error message. Which is completely new to me and I never handled this sort of problem. I should not install online? What is the system requirement? Now I have Windows 8 operating system. Please guide me to find the cause. Thanks.
Image of the Error
Error Message in the Image
Error
The “NI LabWindows/CV1 2012 Network Variable Library” installation has failed with the following error:
An error occurred during installation of assembly ‘NationalInstruments.NetworkVariable, version=:8.6.20470.”,culture=”neutral”,publickeyToken=4544464CDEAAB541”,processorArchitecture=”x86:’. Please refer to Help and Support for more information....
Read moreHi Friends,
Clipboard Help and Spell check installation went successful without any abruption. But when I startup the program error appears, operating system is windows 8 64 bit. What helps me to solve this error? I tried by trouble shooting the program by step by step but not able to guess the error? I cannot fix it. Help please.
Error EX4: DBISAM Engine Error #11013 Access denied to table or backup file ‘query (129241)’
Read moreHi, During the installation of AutoCAD update got an error message. I am not able to proceed few steps, got this error in the beginning of installation. Error describes I updated by other means, to my knowledge I never updated. Is there any way to get updated automatically? Working with AutoCAD is my profession. Guide me to fix the problem.
Image of the Error:
AutoCAD Electrical 2011
Error 1328. Error applying patch to file
C:Config.MsiPT359B.tmp. It has probably been updated by other means, and can no longer be modified by this patch. For more information...
Read moreHi Pro,
I made an attempt to install AutoCAD 2013, but got stuck up with an error message and it blocked me going further. I have windows 8 64 bit operating system and have some different Autodesk application. Is any previous application software is blocking this? I have a doubt whether anti-virus protection is blocking this AutoCAD service. Help me solve this problem.
Image of the Error
Failed to launch Exchange Host Application
Failed to execute Exchange Host application C:ProgramFilesAutodeskAutoCAD2013AdExchangeAcBrowserHost.exe.
Error: The system cannot find the path specified.
Read moreHello experts,I was using Skype for quite long time, when I try to open Skype all of a sudden I got his pop up message. It worked well in Xp operating system, but this happened in windows 7. Tried million times to uninstall and reinstall the Skype, but nothing magic happened. Also I updated my operating system and also updated my web cam and microphone too. Experts help me solve this issue.
Exception EAccessViolation in module ntdll.dll at 00032239.Access violation at address 777F2239 in module ‘ntdll.dll’. Write of address 00000014.
Read moreHi Troubleshooters,
I am crazy about movies and videos. So friends coming to the problem, I converted Tp files to DVD or Divx and Mpeg2 it was good and no issues. It also works well to a core in 1080i, 576p and 576i, but problem is not DVB-T Lite. I am not a technical person, not able to proceed further. Please guide me.
FusionHDTV DVB-T Lite doesn’t support FusionConverter/
Please visit our web site at “http://www.dvico.com” for more detail information!
Read moreHI folks, this is simply irritating, whenever I try to open Trillian Astra error message pops up and there it stops to run further. This message also pops up with other programs like iTunes too. My system is upgraded and it has all minimum requirements. Your help will be appreciated. Thank you.
The procedure entry point _p could not be located in the dynamic link library SHELL32.dll.
Read moreHello friends,
I tried to install the fusion application using proxy server but I ended up with an unexpected error. Is this the correct method? I am the authorized person to do and moreover there is no one. My operating system is MAC OS. So please help to sort out the issue to find solution.
Image of the Error
Unexpected Error
[Error 20] Not a directory: ‘/Users/Kaed/Applications/Fusion360.app’.
Please attach the file “/Users/Kaed/Library/Logs/autodesk.webdeploy.streamer.log” to any problem reports before closing this dialog.
Read moreHi there,
I like to play different types of games, love to play. While playing NVIDIA, minecraft I ended up with an error message and can’t play the game further. After this error not able to open the game, why this happened? Then I try to reinstall it but no luck. How can this be fixed? Friends guide me to fix the error and help me to find solution.
Image of the Error
NVIDIA OpenGL Driver
Too many errors occurred, which indicates a serious problem from which we cannot recover. The application must close.
Error code:...
Read moreHello tech savvy,
I successfully installed the TeamViewerdaemon in the UBUNTU operation system without any error. Though it is successful I am not able to run the program. I start the daemon and it has all access still it is not running. How do I obtain this log files? Any hints how it works? Help please.
The teamviewer daemon is not running!
Please start the daemon (needs root permission) before running TeamViewer:
teamviewer--daemon start
If you did not disable the daemon, please contact TeamViewer support. Run the following command to obtain all log files:
teamviewer--ziplog
Read more
