Archive
Hi brainy,
I am using windows phone for past few months, good. Used to download and install simple games for my kid to play. Recently when I tried to download using my Wi-Fi network, I got this error message. After a while I tried again no further improvement and even I checked Wi-Fi connection and password looks good to me. Assist me please.
Image of the Error:
Error Message in the Image
There has been a problem completing your request. Try again later
Error code: 805a0193
Read more
Hello friends,
I don’t know why I am getting this kind of installation problem. Original version of Autodesk AutoCAD 2014 with a license bought from store. While Installation I got this error message ‘could not access network location’ system is not in network, I am administrator and user. Why I am getting this error, please explain. Your help is appreciated.
Image of the Error
Error 1606.Could not access network location AutodeskAutoCAD2014R19.1.
Read more
Hi Brainy,
This is very interesting and fun to use the Nero burning ROM. I used to create easily the Blu-ray disk previously without any problem. But now I tried to update my older version to latest version, while installation it throws me an error message. Folks help to find the error? Which one is causing error? I am totally blank. Help please.
Image of the Error
Nero Blu-Ray
Error 1326.Error getting file security: C:ProgramDataNeroGetLastError: 5
Read more
Hi Whiz,
I added a new user to a published application; it went good without any error. And then when I try to see the application’s properties I got this error message, “access denied”. This is as a result of denied access or the data corruption. To be in safer side I started taking data backup, to restore it. Whizzes assist me to find an answer.
Failed to read application properties
Read more
Hi experts,
I am having problem for quite long time and tried again and again, getting tired of this error ‘Failed to connect to network adapter’. I disabled firewall; other antivirus thinking of this might help to connect. And I reinstalled the Hamachi and tried again no magic happened. Deleting and re-configuring the adapter settings might help me? Tech support friends help me.
Failed to connect to Hamachi network adapter.
If you just installed or updated the application, please try restarting Hamachi in as few seconds. If the problem persists please report the incident in Tech Support Forums...
Read more
Hello ally,
When I try to install the Autodesk 2014, couldn’t able to complete successful. Ended up with an error message, installation stops there. Operating system is windows 8 and I have installed it before. Not able to figure the root cause? May be some files corrupted while downloading? Allies guide me to find the error. Thanks.
Image of the Error
Autodesk Maya 2014
Error 1311.Source file not found:
E:Autodesk_Maya_2014_dlmx64MayaMaya2014.cab. Verify that the file exists and that you can access it.
Read more
Hi all,
I installed the Trillion pro through download and it keep on crashing every time I login. Any dll file is making this problem or any file is missing. I tried again by reinstalling it and for your information I didn’t make any changes in my system. I am new to this program need your help friends.
Trillian has encountered an error and must close.
Please take note of any changes you’ve recently made to Trillian and try to reverse them if possible.
(C:Program FilesTrillianCrash Filescrash.1134231511.dmp)
Read more
Hi all, I was trying to install Defraggler in the system, but error message pops up. It displays it cannot access the specified file. So I run the installation program again as an administrator but again it fails to setup with same error message. So I sent a message to system administrator. Please help me to solve this problem.
This installer requires you to be logged in as an Administrator
Read more
Hi Friends,
I am a gamer, but I don’t like this Battlefield 3 game. Because whenever I play this game it always showed me some error, not allowing me complete the game. I thought the system configuration might be the problem, so after upgrading my system to windows 8 played again ended up with different error DirectX error. Friends give me some suggestion to come out of this error. Thanks
Image of the Error
DirectX Error
DirectX function “GetDeviceRemoveReason” failed with DXGI_ERROR_DEVICE_HUNG (“The application’s device failed due to badly formed commands sent by application. This...
Read more
Hi ally,
It’s not easy to get a free anti-virus in the market to protect a system from mal virus. With luck favoring I got one now the problem is I got stuck up with the error message ‘failed to load the resume file’ don’t know what to do with this error? Do I need to remove the old version before installing the new? Or simply I need to select the update option. Allies, you know how important is? Your opinion and solution is appreciated.
Image of the Error
AVG 2014 Installer – Error:...
Read more
