Archive
Geniuses help please,
Initially thought that calc.exe might be infected by some virus, not able to recognize or find with antivirus. I know it’s a windows application program, so is there any way to fix this without reinstalling operating system. How to know the installation is 100% successful. I get this error often when I open, but it works sometime. Guide me to find the solution.
The application failed to initialize properly (0xc0000142) . Click OK to terminate the application.
Read moreHello tech savvy,
I am a gamer, curious about new versions and new upcoming games. I love to play games. But now I am struggling with this error, I am good gamer not a technical person. When I try to update by Xbox I got this error. I tried by re-installing it again and also I cleared the Xenocode folder, nothing works. Still I have this error, please enrich me with some suggestions.
Image of the Error
Error Message in the Image
Xenocode Virtual Application Studio ISV Edition
The application has encountered and error: Catastrophic failure (0x8000FFFF)
Please contact the publisher...
Read moreHello,
I am using Webroot SecureAnywhere and after an update to 8.0.2.14, I found that my firewall and security shield are disabled. I tried to fix it using a work around that suggested that I reactivate the same key code. When I try this, I end up with the error ‘FZL2222: A replacement key code has been issued and must be used with this product line.’ I tried this several times. But every time it is the same result. I don’t know what to do with this problem. I am hoping any of you experts could offer me some tips....
Read moreHello Everyone,
I am facing a problem with AVG Free 2013. I cannot save the settings configured by the users. While trying to save, an error message is displayed saying that ‘the specified file is not found’. I tried to edit the settings after restarting the system. But this did not help to fix the issue. I also tried uninstalling and re-installing AVG. But it didn’t help me either. I am using windows 7 on my computer. I was wondering if any of you forum members could help me out with this issue, please. Your valuable suggestions will be greatly...
Read moreHello troubleshooters,
It’s very urgent help me to recover data from hard disk. Accidentally some of data in the hard disk is erased. So I used piriform to recover my data but it is showing some error. I want that data it’s important to me, how do I get it through Piriformrecuva? I any other option is available to recover my data? Help me friends.
Failed to scan the following drives:
G: Unable to read MFT
Read moreHello pro,
Microsoft word is my world; all my document work is with Microsoft word. A bit I have a simple or common error which is resulting by adding or inserting an equation in the word document. Everything else is working to my knowledge. Using Windows XP operating system, so I need to reinstall Microsoft word? And I tried this in windows 7 same problem. Pro’s assist me to find the solution. Thanks.
The program used to create this object is Equation. That program is not installed on your computer. To edit this object, you must install...
Read moreHi Pals,
KMPlayer gives ‘Access violation at address 00C411B4 in module KMPlayer.exe’ error whenever I try to play any MKV file with the KMPlayer. I tried reinstalling a couple of times; but was not successful. I also tried deleting the ‘gen_ml.dll’ file. But this too was not of any particular use. I am using KMPlayer version 3.7. How can I get rid of this problem? I have run out of ideas. Have anyone faced a similar issue? I am waiting for your help.
Access violation at address 00C411B4 in module ‘KMPlayer.exe’. Write of address 00000048.
Read moreHi friends,
I am unable to use some of the programs installed on my computer after I downloaded the Bitdefender antivirus. On trying to launch the application, I get the error message “None of the dynamic libraries can be found: sqlite3.dll”. I installed the 30 day trial version of Bitdefender Total Security and on getting this error, tried using Bitdefender Antivirus Plus. I’m still getting this dynamic libraries cannot be found error. Is this a problem with the antivirus download or is there a work around for this problem? I would like to continue using this antivirus as I really...
Read moreHi Forum Members,
Whenever I try to open a new file in KMPlayer, it gives an ‘Access violation Error in module KMPlayer.’ A screenshot of the error message is given below. I tried to uninstall the KMPlayer and reinstall it with its latest build. But still the problem persists. I also tried deleting the module ‘gen_ml.dll’. But this too didn’t fix the problem. I am using 32 bit Vista Home Premium. I don’t know what more to do with it. Does anyone have any ideas on how to fix this problem? Your help will be greatly appreciated. Thank you.
Hi DBA, when I am trying to install PostgreSQL 9.1 got a peculiar error message, which I never experienced before. During the procedure the system restarts, I didn’t see the Postgresql on startup. I got this error message. So I was trying to retype the password in the server properties, but the problem persists. Help DBA’s?
Windows could not start the postgresql-x64-9.1 - PostgreSQL Server 9.1 service on Local Computer.
Error 1069: The service did not start due to a logon failure.
Read more
