Archive
I have been trying to install Skype Portable in its own sandbox but failed to do so because of an Application Error. When I try to install it I get the following error message. ‘Memory could not be read. Click OK to terminate the program’. A screenshot giving the detailed message is attached below. I am using Windows 8.1, 64 bit and Sandboxie 4.07.03. I am getting the same error when I try to install regular Skype too. Does Sandboxie prevent installation of Skype? I did not get any info regarding this. Could anyone give me solution to fix...
Read moreHi tech expert, I got an error when I was in the middle of compiling eMule.exe. To my knowledge I doubt the property page might be the cause for the issue. So I checked the page but not able to find cause. I also added SafeSEH option to the linker of Project eMule. I checked the settings all libs, Atlserver and WMSDK are all included. So help me friends.
eMule.exe was not linked with /SafeSEH!
Read moreHi experts,
I am little confused with this simple error message. From the error understood that number in line 4is too large than the desired one. It means data is assigned to null value or integer larger, don’t understand exactly. So the oracle Number (p,s) is wrong? If I change will it work? Help me experts.
ORA-06502: PL/SQL: numeric or value error: number precision too large ORA-06512: at line 4
Read moreHello friends, I got this error whenever I try to run the java class file. Is this is common error? Thinking this might be the java version problem? I was using old java compiler so I tried updating with higher version but still the error is not going off. Please help me resolve the issue.
An error occurred:
java.lang.UnsupportedClassVersionError: Bad version number in .class file
Error log: /private/var/folders/uC/uC2zT7wvERu6+Ks8omTgm++++TI/-Tmp-/install4jError1579327149539064825.log
Read moreHi Experts,
This is very tricky and challenging for me, got an error message ‘Cannot remove a CVS module which has module mappings’. Googled it there is no similar problem I can see in the forums. This made me even more desperate. So I am confused what to do next, hooked up with this error. Experts in this can guide me or help me to find the solution.
Can NOT remove a CVS module which has module mappings
Read moreHello friends, I don’t understand the reason for this error when I choose the online migration from context menu the error dialog box opens. Just want to make sure whether this is the only option available to migrate data? Do we have alternate one? I have a doubt does the data in the table affects? So help me friends.
There are no EnterpriseDB Clusters configured, Can’t launch dialog
Read moreHi tech professionals,
This is weird problem, not able to find a solution myself. Tech professionals, I am seeking your help to solve this error. The error occurred while I am running EJB Application. Guessing this error might be with file path or with the class structure, not sure where it went wrong. Help me to fix it.
Launching 'EJB Application client' has encountered a problem.
Exception occurred executing command line.
Read moreHi,
I am using Windows 7 machine, 64bit and installed CCleaner on my Intel Core2 Quad CPU Q9650 @ 3.00 GHz with 8GB of RAM with ATI Radeon HD 4850. When I try to click on tools in CCleaner menu, it throws up this error. I tried to uninstall and re-install CCleaner and tried to play with various configurations but it won’t help. Anyone have a similar problem and solved it, please help. Thanks in advance.
Unexpected error
Unexpected error
An unexpected error has occurred in CCleaner.
error description:AtIThrow: hr = 0x80070057
CCleaner v2.25.1025
MS Windows 7 Ultimate 64-bit
Intel Core 2 5Quad...
Read moreHi,
I have AutoCAD 2011 and I was recently working on it on a network sharing the drawings. When I try to load a drawing, this error comes up saying “FATAL ERROR Unhandled Access Violation Reading …”. I tried removing network drive sharing and re-sharing again and resetting all network drives. I am using Windows 8 (64 bit). Any help solving this issue would be greatly appreciated. Best Regards.
FATAL ERROR Unhandled Access Violation Reading 0x002a Exception at e57bb324h
Read moreHi,
I am using Windows 8 PC, 64 bit with 4 GB of RAM. I am trying to open One Note notebook and create a new section in my OneNote, I get this error continuously every time. The application freezes and I had to kill it using the task manager. I tried restarting my PC several times but still the same problem. Someone please help. Help will be greatly appreciated. Thanks.
ONENOTE.EXE – Application Error - The instruction at 0x777708c5 referenced memory at 0xffffffff. The memory could not be read. - Click OK to terminate the program
Read more
