Archive
I installed Adobe Dreamweaver CS5.5 on my Windows 8 PC and I had a successful install. I started the application and used it for about an hour and a half and saved the work. After I saved the work, I closed the application and restarted it after an hour or so and its giving me this error and asking to uninstall and reinstall the product. I am totally confused. I tried to uninstall and reinstall but it’s doing the same thing repetitively. Please help!
Configuration error – Please install and reinstall the product. If this problem...
Read more
I am trying to render FCPX but it became useless as I cannot export the Master files. I just upgraded to OS X Mavericks and I am getting the error below when trying to export:
The share operation Master File has failed
The operation could not be completed because an error occurred when creating frame 19186 (error -1).
I already tried to clear the render files but it only works in one project. Can someone please help me fix this? Thanks.
Read more
I have a Logitech C600 webcam running on my Windows 7 PC. It was working fine before but since yesterday I was having some issues when I enable preview. I am getting a black screen only following with an error message as shown below:
AMCap
Unable to add the video capture source to the filter graph.
Class not registered
[0x80040154 / 10683]
OK
I even tried it on Skype but it only detects the speakers and its microphone. The video was not detected and I can only see black screen. How can I resolve this issue?
Read more
I have CorelDraw X4 installed in my computer which is Windows XP and suddenly an error popped up saying “Try restarting your computer and then restarting the program. If these actions do not resolve the problem, please uninstall and reinstall the program. (Error 38). I tried uninstalling and reinstalling the program and it worked fine for once but again I see the same message. Next I tried holding the F8 key while starting CorelDraw to bring it to factory default but have the same problem come back. I am struggling and any help would be greatly invited. Many Thanks.
Read more
I was working on my Windows 7 PC with my PDM Workbench and I tried to create a design table for a CATPart. Next I tried to create a Document item for the design table and upload the file by updating to PDM. I was hoping to see the updated design table related to the CAD document, but I got this error that “CATIA has stopped working” and it crashed. I am not even able to save the file locally on to my hard disk. Anyone knows why this is happening? Help would be greatly appreciated. Thanks.
Read more
I have my UNIX machine where I am trying to calibrate the NI 9201 with NI Calibration Executive which I downloaded from the internet. While calibration operation, it says “The driver on your machine does not support the device you are trying to calibrate. Please install NI DAQmx 8.5 or higher. I am not sure what kind of driver it’s asking for. I tried to uninstall and reinstall NI several times but get the same error. Anyone getting similar error please help. Help would be greatly appreciated. Thanks.
Calibration Executive – The Driver on your machine...
Read more
I am having Windows 8 PC, 64bit with 4GB of RAM. I recently got this error asking me to uninstall the Synaptics driver which I have no idea. I am sure that I had this Synaptics Touchpad driver installed in my laptop. After using for some time, I get this error. I tried to uninstall and install the driver manually, but it still won’t like it. I went on to the laptop website and downloaded the drivers twice and tried to reinstall but no joy. Please help. Thanks.
Synaptics Pointing Device – Unable to connect to...
Read more
I am trying to install SolidWorks 2012, student version on my windows 7, 64 bit machine. I install proceeded till 29% when it stopped and threw out an error “RollbackUnReg_DocMgrDLLxxxxxx”. I uninstalled the program and installed it again and getting the same error on another percentage. I tried to get the correct Visual C++ Redistributable x64 package and installed but of no joy. Please help.
SolidWorks Installation Manager
Internal Error: The Windows Installer for this product component did not run as expected: RollbackUnReg_DocMgrDLL.xxxxxxxxxx.
Contact Technical Support.
When contacting Technical Support about installation issue, you will need to provide the...
Read more
Hi expert friends,
I am not able to use the Serato scratch live for real-time control of Ableton Live; it is not synced to a deck and I am not able to check the tracks. Here I am able to save the version but not able to run in 64-bit version. Is it a problem with the Application? 64-bit cannot support the Ableton Live 8? Please help me. Your help would be great.
The 64-bit version of Ableton Live 8 cannot run on this computer because the processor does not support certain required features (CMPXCHG16B instruction)
Read more
I downloaded Adobe CS4 product install from adobe website and installed it on my windows 7 computer. The install completed ok with no error and showed a success screen at the end. I exited from that screen and tried to open the newly installed Dreamweaver program from the program files menu and it gave me an error like “This product has encountered a problem which requires that you restart your computer before it can be launched”. I am not sure what this error means. Can somebody please help me understand this? Any help would be greatly appreciated.
Read more
