Archive
I am trying to update the Google Chrome in my laptop by going to the about page and checking for updates. But I keep on getting the error that "Update server not available: error 3). What can I do to successfully update the Chrome browser? Can Google chrome be installed from a website other than the official Google website?
Read moreI have a Toshiba Satellite core i5 laptop that I bought a couple months back. Everything worked all fine until it mysteriously started dropping WiFi signals off and on. The WiFi router at my home is continuously on. All other devices work fine with the WiFi. Is this an issue with the WiFi antenna in my laptop? Or is it a driver / software related issue? Please guide how to fix it.
Read moreI am using VFP 9.0 service pack 2 and trying to call a web service. The website that is hosting the service I require is only available via HTTPS. While using this service with ASP.NET, i get no issues but when I use VFP to access, i get an error as, "Error: 1429 - OLE IDispatch exception code 0 from Connector: Connector:Bad certificate." Is that an issue with web services and VFP that require SSL?
Read more
Hello! I am thinking about changing my cell phone and there are two phones that I like. One is a Nokia Lumia which is a windows phone and the other is Sony Xperia which is an android phone. Which OS is better? Which OS has more range of applications? Is android OS more user friendly or windows OS? Suggestions please!
Read moreI recently changed the hard disk on my HP Pavilion dv6 laptop as I needed more space. I created a recovery on an HP USB that has 16 GB storage space. I am trying to run the recovery but it gives an error 1005. I have tested my hard disk as well as the USB disk for the errors and have run memory tests on both of them. Tests came out good. What can be the problem? How can I succesfully run the recovery? Please help.
Read moreI am trying to open a file that was sent to me by a colleague. It is a Microsoft Excel file and I am trying to open it in Excel 2007. It gives me a runtime error message whenever I try to open it. What can I do to open the file? What does runtime error mean?
Read moreI am running Safari version 4.0.3 and trying to download Mozilla Firefox on my MacBook. The download starts fine but when it ends, an error appears that "Safari error Domain error, the operation could not be completed". Due to this the file does not open and I am unable to install Firefox. I have tried emptying the cache on Safari and I have also tried resetting it but up to no good. How can I fix Safari so that it will download properly?
Read more
I have an android phone that has over 2 GB of free internal memory at present. But whenever I try to install a new app in the phone, it says that memory is full and transfer data to SD card. Is it a problem with android OS? Is my memory really full and not being shown as full? How can I clear my memory and create space for new apps?
Read moreHi everyone! I need suggestions on which is cheaper, buying a new PC from a brand such as HP or Dell, or is it cheaper to build your own personal computer by buying different components from the Market? Kindly also suggest me some places where I can buy computer hardware components for cheap. The budget range is around 600$. Suggestions on what to buy would also be appreciated. Thanks.
Read moreI have an outlook client that I use to read my emails, However recently I have noticed that I'm unable to receive emails but I can send, what could be the problem? I have not changed my settings in my email client, how can I trouble shoot the email account using the email client? Is there unique software that can be used to effectively check for this fault?
Read more
