Archive
First of all, I would like to know if you can install SVN on computers using Linux-based operating systems. If this is possible, then could you also guide me with the steps I need to take in order to install this software on my Linux machine? Please provide some information on practical ways I can configure the software to maximize the benefits it offers.
Read more
I would like some information about SVN. What is SVN and how do you use this software? On which computing platform can you install SVN and how can it be of benefit to me? Does using SVN make life easier when working on projects and how does SVN achieve this?
Read more
Please help me by providing sequential steps I need to take in order to install CVS on a Linux operating system. What are the requirements for installing a repository like CVS under different versions of the Linux operating system? Is the procedure the same for installing Ubuntu, Centos, Redhat and Suse?
Read more
Could you explain the concept behind CVS and the steps I need to take to install it on a Windows machine? Why is it good to use CVS in software development? What kind of projects will require the use of CVS? How can it be optimized to perform even more efficiently?
Read more
A new handset. When I connect my Nexus 5 with my PC via USB, it does not show up when I selected device MTP (Media). It seems when I selected "camera (PTP)" but that does not mean access to all the files I need to get you to give me. I have the USB drivers installed. I reinstalled the drivers, the USB debugging is turned on and off (for installation and connections), restart the PC and Android after each change, I am using the cable supplied with the camera, but I'm stumped on this update. I want to know...
Read more
In my asp.net application, users can upload / download files and ASPX files are accessed by the user later (it must implement security at the code level, because it would be better to use the application with minimal permissions to run). So now I have to save these files and where is the best place to store them. Should I give permission to record low in the current project to create or should I create a separate like "www.mydomain.com/files" and up virtual directory. I also want to prevent restarting the application domain. What is the best option to deal...
Read more
I'm doing a project in which two people have a webcam on a site I am creating interact. Do you know of a tool (language, code or program) that allows (free) to raise a cam on this website for me So far, I knew about HTML, CSS, JS, jQuery and PHP (web part), but I think that none of these languages ​​is the best way to access this category. Can you help me ?
Read more
I'll let a trip abroad, and I want to present my updated application for review today, because I do not really want to take my laptop with me (even if it seems that I might have to). It is important that I briefly the application before I go back (mid-August) due to rush back to school for educational applications. The application is ready, but my distribution profile has expired. Website developer at the bottom right now, what are my options for the presentation of the application.
Read more
According to my hypothesis, there are hundreds of millions of Chinese mobile phones (or clones branded phones) there. And it seems, firmware, and operating system for mobile phones are the same. These phones differ only in their design and can be material. I wonder if there is no software development kit or support the development of mobile telephony. What is the operating system and / or firmware included in these phones are those open source or get anyway available online Perform these phones support Java Where to find more information about these devices and software online.
Read more
