Archive
I have a Sony Xperia T3. My phone got pretty slow lately and last night it went black. The notification light was blinking but the display won't turn on no matter what I did. I kept on trying for two hours but to no good. I tried connecting it to my laptop as well but nothing happened. Is my phone dead for good? Or is it a problem with my display? If not, what can I do to recover my phone? Are there any soft wares available to recover the phone from such a state?
Read moreWhy does the conditional validation rule fail to restrict the rule set? I need to compare the current cell against the value returned by a function. I use this formula to prevent a person using the workbook from entering a date that falls on a weekend:” = (WEEKDAY(C4)<>2, WEEKDAY(C4)<>7)”. If C4 is the cell that containthe validation rule, What prevents the formula from forcing C4 to adhere to both restrictions?
Read moreWhy is my MPI program not compiling? Please I am trying to run a Message Passing Interface (MPI) program with C language. I have installed GNU Compiler Collection compiler and the openmpi libraries. I am running Ubuntu and Netbeans interactive development environment (IDE). My challenge is that after including “mpi.h” in my header file and compiling the application, the complian i get is: “fatal error : cannot find file mpi.c”.
Read moreWhy is my amazon kindle fire HD 7 rejecting new files? The tablet said there is no more storage space on the tab, but all the files on the kindle fire memory is 6 gigabytes and the tablet storage capacity is 8 gigabytes. How can I assess the remaining 2 gig space that was restricted by the device?
Read moreHow will I make my WordPress website plug in to work after installing a new theme? I install a new Wordpress theme and almost all my plug inns are no more working. I contacted the same vendor about the problem, but he said the theme is compatible with all the plug ins that are not working. Should I disable these plug ins and try another plug inn with the same function?
Read moreWhy is a file transfer between my personal computer and Android device using ES explorer not working? I recently read a review about how to transfer files between PC and Android wirelessly online using ES file explorer. After I enter the IP found in the remote manager on my PC, I got the information that file path not found. What path is the computer complaining about?
Read moreWhy is my laptop emitting much heat and the mouse unresponsive? I have recently upgraded to Windows 8, and the my system stops working properly. The system is now overheating, hanging, most programs would not work, and bluescreen. I upgrade from Windows 7 and the system configuration are: 4 gig RAM, Intel dual core processor. What should I do?
Read moreWhy is my IP address different from my location? I am having a serious task in changing the system IP to my Location IP. This has started after I install a VPN on my laptop, now my IP is showing Afganistan. I later disable the VPN program, but yet the IP remains the same. After I uninstall the program, the system stop browsing altogether. What is the cause of this behavior? Also, what option do I have to reclaim my IP?
Read moreWhy is Microsoft Excel always corrupting my XML file? My work required that I import a lot of XML files to Microsoft Excel for analysis, after the successful mapping of the XML file using excel, but when I tried to import the file, I got the message that the file is corrupt. When I check the XML file using XML editor, the files seem to the okay. What can I do to import this file to excel without it being corrupted?
Read moreWhat is the best approach to reduce the rate of data consumption of my window 8 operating system? The rate at which my window 8 uses data is really mind boggling. Just surfing the internet, behold 3 gigabytes of data were finished within 2 hours without watch or download video or files. Even after I disable automatic update, the data usage is still high.
Read more
