Archive
Why is my visual studio expressing for desktop installation taking longer than expected without finishing installation? Whenever I try to install this visual studio software, the installation will go on for a longer time until I force shut my system. The worrying thing about the installation is that, anytime I start the installation, the system usually stops working and hang.
Read moreWhy is the install antivirus program always disappearing on my Dell Inspiron laptop? I have installed this avast antivirus software on my dell laptop for many times now, but whenever the system request for a restart after installation, the amazing thing is that the newly install antivirus software usually disappear form the program list and the whole system.
Read moreHow can I use my iPad 2 air to send files and applications to an Android device? I was trying to send some files from I pad 2 Air to a tablet running android operating system but the two devices are not paired. I later found out that the two cannot pair. Why is the two devices not pairing and is there any way to send files from either of these two devices to each other
Read moreWhy is my Gmail auto responder sending the message that it was not supposed to send? I recently set up an email auto responder with my Gmail account and it is sending messages to all the contact in my mail. the most annoying thing is that, the auto responder is not sending mail to the list it suppose to send it to. what could be wrong? and how do i correct this problem?
Read moreWhy is my laptop WI if difficult to off after it was switched on? Whenever I switch on the Wi-Fi of my system, to switch off the Wi-Fi is almost impossible. These started after I install new VPN software. The most annoying thing is that I can’t even control who uses my Wi-Fi as anybody within reach can easily connect to my Wi-Fi.
Read moreWhat happen to my computer system to shut down after blue screen? Blue screen in now the new occurrence to my system. I notice that this blue screen happens most especially if am working with Mozilla Firefox browser. Before the shutdown, my Avg internet security normally warns of high memory use by the Firefox browser. Is this shut down cause by the high memory usage of the browser or because of a serious hardware problem?
Read moreWhy is my compact Presario notebook laptop shocking? I found out recently that my compact laptop is shocking people if you touch the some of its peripheral components like the speaker or the non-plastic parts. This behavior started after I use a friend charger to charge the laptop. Although, if the laptop is not plugged to the main socket, it won’t shock.
Read moreWhy is my blackberry Z3 smartphone selecting a charger before it charging? My blackberry phone started selecting charger. Sometimes it will display charging, but after some time it will display charger not supported. Although, after some time if the charger is removed it may start charging. Is it a virus that is causing this behavior or it is something more serious?
Read morewhy is my wma file fails to convert to mp3? I need to convert some of my files in wma file format to another format, but the conversion is taking longer than usual. Worst of all, the file won't convert, displaying the corrupted file. I thought this is largely due to the conversion tools (Software) amusing, but after trying many different conversion software, the result is still the same.
Read moreWhy is my skydrive not verifying the email address I share my file with? I send a skydrive link to a colleague to access a file on my skydrive, but he log in with a different email address different from the one I use in the invite and skydrive doesn’t complain, granting him access. Is my skydrive under attack? How can I enforce skydrive to strictly enforce the email in the invite sent?
Read more
