Archive
Which is the best virtual software to a windows operating system in Linux platform that can be able to handle games with a higher GPU ? Is it possible to increase the GPU in Linux or how would you increase the overall GPU for a virtual windows 7 running in a Linux environment?
Read more
How do you create a bootable disk from a USB drive and what software can I use? I need to install Linux mint onto a mini laptop that has no DVD drive. Is this method of installation faster than the ordinary disk that is usually used for installation and can this infect my computer when installation process is going on.
Read more
How much does a 3D printer cost and where can I find one? What is the medium that is inserted on the 3D printer to be printed on? Do these printers actually come in a smaller size and how portable can they be for an average user who works travels a lot and may want something that he/she can move around with?
Read more
I want to connect windows to Linux but I cannot see the Linux computer in windows how can I go about this? I have heard of SAMBA how do I get to configure this? Is it possible to share a printer in Linux on windows because I would like to host my printer in windows and use linux for day to day applications?
Read more
Which one is the best email protocol for connection between POP3 and IMAP? What are the advantages for one using IMAP over POP3 and is it possible that one can use IMAP to setup a yahoo account? If so please help me configure my account to IMAP for my yahoo account?
Read more
I am using MATLAB 2009a on Windows 7 32 bit. I am trying to run this program that includes a mexmaci file, a mexw32 file and a cpp file. I tried to run the program but got an error that said, "Could not detect a compiler on local system which can compile the specified input file(s). Error using mex (line 115) Unable to complete successfully". How can I execute my program correctly? Is the error because of files that are not supported by MATLAB?
Read more
My desktop PC has two fans and one of the fan has started giving noises after a while has passed after turning on the computer. This usually happens when I am running high end games or applications. Also the PC has started becoming really hot due to one fan not functioning properly. Can I fix this fan? Is it repairable or will I have to replace it?
Read more
I would like to program my Skype to answer automatically especially through sms is it possible to get a commercial end of such a software because I’m not a programmer and if so how much can it cost if I were to ask a programmer to build me one? What is the maximum video calls that Skype can make at a given time?
Read more
I have a latest dell laptop with Windows 8 Pro installed in it. I am trying to connect to my network via a VPN and I cannot do so. Whenever I connect through the VPN, i get no network access. When I connect without the VPN, i get network access. Is it a problem with my VPN software? I am using Hotspot Shield. Is this an issue with the network configuration? Has it something to do with Windows 8?
Read more
I recently came across a wireless keyboard with a friend of mine and I would like to buy one, what is the maximum operating speed? Are there any rechargeable battery powered types that I do not have to buy a battery to operate? What would be the price estimate of such? Which one is the best ?
Read more
