Archive
| A One way function in cryptography is a mathematical function which is easily solved in a particular direction, but would take very long to crack when used in the reverse direction. Where can we use one way function. Explain the mechanism behind a one way function as used in cryptography. What is a trap door one way function? |
Read more
| I want to protect the formulas that i have created in Excel.What can i do so that my formulas are hidden from all.I want Excel to hide the formulas but display the results only.What can id o to make this happen?What is the difference between the property 'locked' and hidden in Excel? |
Read more
| How does Excel store dates? How will excel calculate the difference between two dates? Can I create a formula for this operation? Is there any function in excel which will help to perform this operation with ease. What is its syntax? Please let me know where under Formulas can I find this function. |
Read more
| What is Responsive Web Design (RWD)? Why do we need to incorporate RWD in planning for our websites. What are the components of RWD? In what circumstances should one plan to implement RWD for a website? What are the things to consider before going for this approach? Please share some tips regarding the implementation of the RWD approach for a website. |
Read more
What is cross linking in terms of Search Engine Optimisation? Is it an ethical SEO practice? What are the benefits of using it on a webpage? Is there a downside to the use of cross linking? In what circumstances could it be harmful? What is anchor text and how is it used in cross linking?
Read more| What is the risk caused by the recent attack on Sony? The attack is claimed to have released some of Sony's major pictures online, including some to be released in the coming years. It is reported that this might be caused by some data wiping malware. What will be the outcome of such an attack? |
Read more
| What is an Online Transaction processing system(OLTP)? How does OLTP differ from OLAP? What is it used for?What are the two types of OLTP? What is a TP heavy Monitor and what is a TP Light monitor? Where do we use each one of them? What are the basic two functions of a TP monitor? |
Read more
What is Airport extreme and what is it used for?
Apple Airport extreme 2TB has Wifi i know that but why do people use it as it needs a DSL modem separately
Read more
| What is a routing table? What is its purpose in IP enabled devices, like routers and switches? What are the contents of a routing table?What information does a basic routing table display? How can they be maintained? What is the difference between manual routing and dynamic routing? Which one do you think performs better in a network? |
Read more
What is a traceroute? What is it used for? What protocol does it use? What is a hop count? What does it measure? What does the phrase the "time to live" signify here? What is its relevance in a network and why does it have to be monitored? What is next hop?
Read more
