Archive
What is Diffie-Hellman? What is it used for? How is it different from the encryption methodology used in RSA? What is the Diffie Helman key vulnerable to? Is there any reason why it should be preferred over the RSA method? In what circumstances could one chose to use RSA over the Diffie Hellman method? |
Read more
What is a bridge? What is their role in a Local Area Network?What then is a switch in networking? What is the difference in their use?Is a switch similar to a router in operation? Which would be a better option to use, a router or a switch? Which layer of the network is a switch associated with? |
Read more
Where can I view my digital certificate in Internet explorer? What information can I get from my digital certificate? How can I verify that the digital certificate has been issued by a trusted authority? How can I ensure that my private key does not fall into unauthorized hands? Can I renew the validity of my digital certificate? |
Read more
Can I insert comments into a Word document? Where do the comments appear in a Print Layout? In the Normal View and the Outline view I can see the comments in the bottom of the page only. Can I see it side by side in the margin. Please let me know if I can change this? |
Read more
What is the drawing canvas in MS word used for? How does it work? How can I delete the drawing canvas around my object? Can I prevent Word from automatically creating the drawing canvas each time I insert an object in Word? Where in the tools menu can I find an option to turn this off? |
Read more
I need to preview changes before I accept them.
Read more
I would like some help with formatting in MS word. I would like to know if there is an option to find and replace other things than words. For example, I would like to find all the times that I have mentioned America and make it as BOLD and change the font for it.Can I do that? |
Read more
I want to know more about the track changes option available in Word. What does this function enable me to do? Does this function enable me to understand if further changes are made to my document? How can I understand the changes, but yet protect my document from being edited without my permission? What is the function “Compare Documents” meant for ? |
Read more
What is an organic search in terms of Search Engine Optimisation? How will a website using organic search benefit in the long run in terms of improving the share of web traffic routed to the web page. How can the ad revenue of a website increase by the effective use of the organic search methodology? |
Read more
What is the Spider in a search engine? What is its role in the Search Engine Optimatiztion process? What is a Bot in SEO terminology? There are two ways in which a Spider finds relevant data. What are these? What is Metadata and how does the search engine use this in SEO? |
Read more
