Archive
What is encoding? How is it different from Encryption? What are the types of encoding which are commonly used? What is Tactile encoding? On what basis do we select the type of encoding to be used? Can you please explain me the process used for encoding? What is sequence memory and how is it used in the encoding process?
Read more
A network interface card enables a computer to become a part of a network. How is this done? How is a NIC otherwise known as? What are the techniques used by a NIC to enable communication between computers or devices? Explain some new features available in the latest NIC available today which has helped in significant performance improvement.
Read more
Hello, I have just bought the Thermaltake PS-TPD 0850 MPCGUS 1- 850W power supply unit for my computer. When I installed it in my CPU it was fine. But now it is making noises rapidly. The noise is like something is touching it's cooling fan. I checked it, nothing is there. What is this problem? Can anyone help me please?
Read more
Hello, I am an user of iPhone 4s for last few months. A few days ago suddenly my iPhone says ''No Sim card or Sim card slot is empty". It even isn't showing the network bar as it was. I have restored the firm ware, have tried the jail breaking but nothing happened. Any solution for this problem?
Read more
Hi, I am using Esonic G41 CCL motherboard. It is not very old version of these series of motherboards. Though I am having a very unusual problem. Two days ago my Motherboards audio rear jack has been disabled automatically. I tried re-installing the driver, update the driver etc. No result. Is there any solution?
Read more
What are the components of a search engine? What is the use of a program with respect to Search engine optimization? What is the role of the Search engine in SEO? What are the basic actions performed by the search engine which helps users to access relevant data with increased accuracy.
Read more
I would like to set my Skype Number as the contact number for my retail store.I have a need to make outgoing calls at my store.
Read more
What is an Open source web application project in Security? Is it more or less secure than a proprietary one? What could be the downside of an open source project and what could be done better to overcome the shortcomings? What are its advantages? Do you see any downside for a proprietary project?
Read more
What is a broadcast domain. For any particular broadcast domain, which are the computers connected to it. What is a collision domain? How is it different from a broadcast domain? What is a private VLAN? How is the concept of broadcast domain control used in implementing a private VLAN? What is the network layer and what does it do?
Read more
Hi, I am using Samsung 1 TB Hard disk drive. I use two of them in my computer at a time. One is master and another is as slave. But recently I am having a problem. Windows is giving an error message ''Loading failed''. Is there any solution for this problem?
Read more
