Archive
Hello, I am an Android user since it's available in market. I always have important files for my work in my Android. I have to print them often. It is painful for me to print the file by extracting the memory card from the phone every time. Is there any software or any solution?
Hi, I have bought a Sony Bravia NX800 HDTV for my home entertainment recently. Two days ago it was raining and lightening out side. So I put all the connections disconnected. But when the next morning I put all connections on, my Sony Bravia NX800 HDTV shows white and red stripes on the screen horizontally. Can anyone tell me why is this happening?
Hello everyone, lets skip the greetings. For last three days my personal computer has attacked by TROJAN_REGIN.SM malware. Before the attack I was using Avast 2014 anti-virus. The anti-virus couldn't fight the virus. So I had to change the anti-virus, now I have installed McAfee Antivirus with latest definitions. Unfortunately it fails too. Any solution ?
How Can I link two sheets so that the value obtained in Sheet 1 is carried over to another sheet. Explain the steps to achieve this linking. What if I need a row of values to be carried over to another sheet? Do I need to use the same process to get this done? |
Read more
What is the difference between a function and a formula in MS Excel? Do they help in performing similar tasks?Where do I find the functions available in Office 2007? What is the usage of the COUNT function? How is it different from the COUNT IF function? |
Read more
How can I copy a worksheet in Excel into another worksheet in the same workbook? I have a set of data typed in a worksheet and would like to copy the entire content into another worksheet. Copy /Paste would just kill the formatting so, I would rather copy the entire worksheet instead. |
Read more
What is public key cryptography? Is it the same as asymmetric cryptography? Public key cryptography uses public key and a private key for encryption. What is the function of each of these components? What is key distribution in the context of this. What is a digital certificate used for? What is Enveloped Public Key Encryption? |
Read more
What are the different types of firewalls available? How would you differentiate firewalls based on where they intercept the communication? What is a virtual firewall? Differentiate between a virtual firewall operating between a bridge mode and other operating in the hypervisor mode. What is a personal firewall? How is different from any other conventional firewall? |
Read more
A larger MTU increases the efficiency of the network. In the context of this statement, explain what is MTU? How does a larger MTU increase the efficiency? What are some other advantages of a larger MTU? There is also a possible downside to a larger MTU. Explain what this could be. What is jabber? |
Read more
Hello, recently I have bought HP Stream 11 Laptop. This is a very nice cloud storage based Laptop. I am having a serious problem with it. The problem is- whenever I use this Laptop for 4-5 hours and restart it for any necessary needs, the Laptop works very slowly or not responding for at least 10-15 minutes.
