Archive
Hi, I am an Windows XP 64-bit edition. I am using some video editing software. These software needs Windows 64-bit edition to run perfectly, so I need to keep Windows 64-bit edition. I also need to update all of my software regularly. But some of my software isn't responding like before. Such as the Flash player.
| I would like to edit multiple worksheets in MS Excel at the same time. My job requires that I insert values into multiple worksheets or delete a set of values from each one of them. Can I group worksheets together and edit them simultaneously? How is this done? Once I have finished editing, how can I then Ungroup the worksheets? |
Read more
| I have often felt the need to adjust volume in Skype when I am midway in a call. Is this possible? Where can I find the options to do this? Can I do this for audio calls as well? What if the other person cannot hear me? What options do I have to increase my volume? |
Read more
| How many PSTN numbers (or mobile numbers) can be added to a group call in Skype? How will I be charged for this? Will I be charged separately for each call? Are there any additional charges applicable during a group call? Can I recharge my Skype credit instantly if it runs out midway in a call? |
Read more
| What is browser hijacking software? What would it do to my system? Where would I most likely find it? How can I identify one when I see it? Is it some sort of malware? Please share some tips on how to protect my home PC from falling prey to the issues caused by malware. |
Read more
| What is Multicasting? How does multicasting work? What are the traditional ways in which packets are sent between hosts? How is a multicast different from a broadcast? Name the different steps for multicasting? Differentiate between hardware multicasting and IP multicasting. What happens during the mapping of the hardware multicasting to the IP multicasting? |
Read more
Hi, I am an user of Firefox. I use Firefox 34 beta version. I have updated my Firefox to this version two days ago. My problem is, whenever I open five or more tabs in my Firefox it stops responding. The problem is not only with this version but also with other versions too. Any solution please?
I am into creating voluminous reports on Excel and hence would need up to 10 worksheets on an average in a workbook. However, Excel by default provides only 3 worksheets. I would like to know if this number can be changed so that I get 10 worksheets by default in a new workbook.How can i I change this?
Read moreWhat is conditional formatting in Excel? What is this feature used for? Where in the menu can I find the option to set up Conditional Formatting. I would like to highlight alternate rows in a worksheet. Can I do this with the help of conditional formatting? What is the formula I need to set for this?
Read moreWhat is Bit Rate? What is then the Baud rate? How are the two related? What are these two units used to measure? What then is the difference between them? What is baseband signal? What then Is Modulation? What is a broadband transmission?
Read more
