Archive
I have two cloud accounts, drop box and Google, is there a way that I can share my documents from Google drive to drop box and vise versa? The data are so huge that I cannot download them and upload them again. What is the maximum size I can send per given session?
Read moreOur CISCO router is experiencing problems after a recent power outage we had. We cannot find our LAN. I know CISCO routers are known to be really good, but I don't know what happened. Has our router malfunctioned? Is it repairable? Can this be an issue with the configuration that we cannot find our LAN? Please help.
Read moreHow Can I install word press in windows and what is this MySQL that it keeps on requesting how I can configure my computer because I really need to lean to use using word press. Is there a cumulative download that carries the entire word press with the prerequisite software?
Read moreI have a benq scanner 5000 that was came with a 32 bit driver installation disk, is there a way I can run this in a 64 bit? I have tried to search for a 64 bit driver but I cannot or is there way that can run 32bit software in a 64 bit? Which one is the best between a 32bit and 64 bit scanner?
Read moreI have been using the Microsoft Publisher to print nametags for more than a year. The source data is in Access 2007 in a table. But somehow I am not able to do it anymore. I have also tried merging with the Excel file but to no use. What may be causing this error? Will I need to reinstall Microsoft Office all over again?
Read moreI am experiencing this problem for the second day now. Whenever I try to send an email or somebody sends me an email on Outlook 2007, I can not send or receive it and an error occurs. At first I thought maybe the servers are down but it's the second day now and the same problem is happening. Is this an issue with my Outlook account? Can firewall be the reason for this? Will reinstalling Outlook fix the issue?
Read moreI have Outlook 2007 installed on my laptop. When I try to open the MS Outlook it gives me an error that Microsoft Outlook cannot start, cannot open the outlook window. It worked all fine until today. I need to check some important emails. Please help how can I fix this error? If I reinstall outlook, will my emails be categorized as I categorized them or will it sync from scratch?
Read moreI am working with some database files in Lotus Notes with the latest updates of Lotus Notes installed. I am experiencing a problem when I try to email the files to some people. The error appears that "Illegal Circular Use : DocExp Processing". How can I fix the error? Is it some problem with the database files that I am trying to send?
Read moreI was trying to update my Skype to the latest version but encountered an error with error code 1603. After the update failed, I was unable to open Skype. I uninstalled Skype and then installed the older version but still it is not opening. I need Skype all the time to stay in contact. Can someone please tell me what is the problem with Skype? How can I fix the issue? How can I upgrade to the latest version?
Read moreHello. I am trying to charge an iPod shuffle but it is not charging. I plugged the charger into the switch and it did not charge. I thought maybe the charger was dead. After that I connected it with my laptop to charge but still up to no good. It also doesn't show up in iTunes as the battery is dead. How can I fix this? Is it a problem with my iPod or the charging cable / wire?
Read more
