Archive
Hi - Ya,
I played this freerealms in the morning, but all of a sudden I got this error in the evening. This error stopped everything like the sound and even I am not able to enter the games. This means membership is expired? Do I need to update the game? Please help me to find the solution. Thanks.
Title: Freerealms.exe has stopped working
FreeRealms.exe has stopped working
Windows can check online for a solution to the problem.
-> Check online for a solution and close the program
-> Close the program
-> Debug the program
Read more
Hello all,
When I try to login using GitHub account it’s a new account for Phone Gap and in the Ares accounts, I try to enter with GitHub credentials. But it is not allowing me enter with GitHub credentials, I am getting this error message.
Adobe credentials works well for me. I am getting this error because of GitHub? What should I do now? Help please.
Title: Ares IDE PhoneGap Accounts work with error
Unable to check PhoneGap Build Account
Details
Error: Unable to get PhoneGap application token (undefined
Read more
Hello brainy,
I am in a bad situation, when I upgrade my galaxy note firmware via kies in the middle of the process my laptop suddenly went off without the battery. I didn’t realize how bad the symptoms are? Now the Galaxy note does not power on. When I tried again I got this message, how will I do the recovery? No idea, please help me
Title: Firmware Upgrade encountered an issue
Firmware Upgrade encountered an issue. Please select recovery mode in Kies & try again.
Read more
Hi all,
When I am running the program in Emulator stuck up with an error. I made some trail methods by reconnecting and re-configuring it. But nothing helped me to get rid of this error. Is there any limitation in setting up the breakpoints? Don’t have much knowledge in this. Whether we can use adapter? Struggling hard friends, help please.
Words in the Error Image
Critical Error
ERROR : C28xx: Error: (Error 1135 @ 0x3ED18E) The emulator reported an error. Confirm emulator configuration and connections, reset the emulator, and retry the operation. (Emulation package 5.1.232.0)
Read more
Hello Whiz,
I got this error when I am in the middle of Autodesk Inventor 2013 installation. Don’t understand why I am getting this error, when I googled found that Avast Anti-Virus software may be the root cause. Do I need to remove this anti-virus? Is there any other option to go further without uninstalling antivirus? Help Please.
Title: Inventor 2013/2014 + Avast Anti-Virus Software + Red X PLACEHOLDER
PLACEHOLDER
Read more
In Webmaster today i found this message
As in the screenshot
An improvement to our top search queries data was applied retroactively
Any ideas what this is
Read more
Hi friends,
I get a message to restart the operating system after windows update. During the process Internet explorer is open, I got a warning message to close all the internet explorers before the windows restarts. What I have to do now? It gives me two options retry and cancel, which will be good to try. Please guide me to fix this. Thanks.
Reset IE Settings to Default...
There are currently one or more Internet Explorer windows open.
You must close down all Internet explorer windows before reset it to default.
Retry Cancel
Read more
First time I doing this, trying emulator from my Android, not done this before. When I try to launch Titanium Android Emulator it encountered a problem. This means I need to update my version or I need to go back to old version. The message in the log file is empty or blank. Don’t understand it. Anyone can help me to fix this problem. Thanks.
Problem Occurred
‘Launching Titanium Android Emulator - androidfacebook’ has encountered a problem.
This launch uses Av8 Android Runtime, which require Android 2.2 SDK and above.
Please edit your launch configuration to select a compatible...
Read more
Hello tech professionals,
When I compile a video in Camtasia, I ended up with this error message. Video is read from the timeline, why not the audio? Anything I am doing wrong? As in the error message, I saved the project and reopened again but no luck. I did like this for many times, but no improvement. Terribly needed help from professionals. Thanks.
Title: Camtasia studio could not playback audio from the timeline." Error code: 0x8889000f: Unknown Error
We’re sorry! Camtasia Studio could not playback audio from the timeline. Try saving and re-opening the project.
(Error Code 0x8889000f: Unknown...
Read more
Hi trouble shooters,
I am in the process of setting the system, when I came to Windows Live Messenger I ended up with an error message. But I am sure, checked twice password and ID are damn perfect. Why I am getting this error? Do I need to check the internet security settings? Please assist to find the solution. Thanks.
Title: Windows live Messenger error 80048821
Windows Live Messenger could not sign you in because the windows Live ID you entered does not exist or is incorrect.
If you have forgotten your password, click Forgot your password? at the...
Read more
