Archive
Hey,
I am getting this ‘stopped working’ error message when I play a video in VLC player. It gives me an option to close program, when click the entire player is closed. Why I am facing this error? Thinking of this might be the installation problem, I re-installed it again but the error persists. Also I tried playing different formats and different video files, no luck. Anyone experienced this before, please post your suggestions. Thanks for your help.
Title: vlc player 2.1.0 has stopped working for MKV
VLC media player 2.1.0 has stopped working
A problem caused the program...
Read more
While I am trying to update the Open Broadcaster software to latest version I got stuck up with an error message. Error says some dll is still in use, so I tried closing all other program which are currently in use and tried again. But no result, it worked fine before update. Where am I going wrong? Not able to guess, Please resolve this error.
Error:
Open Broadcaster Software Update
Update failed: Graphics Capture Hook 64.dll is still in use. Close all programs and try again.
Read more
Hi all,
Since my update from Visual 2012 to Visual 2013 I am getting this error message. Error is not bothering the review, when I click ok button code review get created without any error. But this error is not happening for code review for pending change. Is it a bug? Or I need to make any update in the system? Please help to fix this error. Thanks for your help.
Error:
Microsoft Visual Studio
Code Review
Some of the reviewers don't have permission to some of the files to review. Do you want to submit the code review anyway?
Read more
Hi Tech professionals,
I am getting this error message, totally upset and I googled and tried lot of things but no luck. For you information I used card reader to import files and with the cameras directly. The 5d footage is from a 5D Mark II.Is it any problem with FCP X? Please help me to find the root cause of this problem and guide to solution. Thanks
Error:
Import Failed
The following clip encountered an error during import and is still referencing media on the camera.
Clip Name: 2013-04-10 11:22:36
Event: AmEdTv
Original Name: MVI_9935
Volume: EOS_DIGITAL
Read more
Hello all,
Friends when I try to save a page document I am getting this error. Means I am losing my saving document or it is not saving in iCloud. Why I am getting this error? Am I going wrong anywhere? Thinking of whether the iCloud version might be the problem. Help please.
Error:
The file “Untitled. Numbers” couldn’t be opened.
Read more
Hi Pro,
I had this error message when I start to install the Viewer 2, what will be the problem in opening file for writing. This error stopped me from further installation in the middle, as per the instruction I retired but no luck. Any dll is missing? How to fix this dll in appropriate folder? Please help me to fix this error. Thanks in advance.
Title: Installation fails: Error opening dll files
Error opening file for writing:
C:Program FilesSecondLifeViewer2llpluginssleay32.dll
Click Abort to stop the installation,
Retry to try again, or
Ignore to skip this file.
Read more
Hi all,
I am getting crimped of Steam and their errors. When I try to play in offline mode somehow I am getting this error message. And it wants to connect to the internet, tired again after connecting same error message appears again. I don’t find any reason for this. Any help would be appreciated, thanks.
Title: Unable to connect to the steam network.
Unable to connect to the stream network. “Offline mode” is unavailable because there is no Stream login information stored on this computer.
You will not be able to use Steam until you can connect to...
Read more
I love to hear songs, that too in iPhone with excellent sound. I have a problem, might be silly I am not able to sync my iPhone with iTunes in my laptop. When I plug in to sync I am getting this error message saying information required for activation could not be obtained from the iPhone. So I tired the common methods like restarting the system, re-opened the iTunes and even the phone, but no luck still getting this error. Any help? Thanks.
Title: The iPhone “iPhone DIABOLIK” cannot be used with iTunes
The iPhone “iPhone DIABOLIK”...
Read more
At home when I updated my Visual Studio from 2010 to visual Studio 2012, after updating when I try to create a SharePoint 2013 projects or sample application I ended up with this error message. So could I able to download and install the Microsoft office developer tools and Web developer tools? Anyone can provide the direct download link? Your help is appreciated. Thanks.
Error:
“An error occurred while trying to load some required components. Please ensure that the following prerequisite components are installed:
Microsoft Web Developer Tools
Microsoft Exchange Web Services.”
Read more
Hi Ally,
Allies during re-installation everything went pretty good to some extent, but I think it has failed to install everything. The problem is after update when I try to open a file in Photoshop CS4 on Mac OS Lion, I got stuck up with this error message. This means the OS function crashed? Don’t get any idea further. Please help to resolve this error. Thanks for your help.
Error:
You can’t open the application bspatch because PowerPC applications are no longer supported.
Read more
