Archive
Hi Everyone,
I got this error from Pro Tools a few days ago. Pro Tools wouldn’t start after this message is displayed and I had to force quit it. I am attaching a screen capture of the error received. I have absolutely no idea as to what caused this. All I know is Pro Tools was working fine two days back and now it doesn’t. I am running Pro Tools 9.0.6 and OS 10.8.5 on a Mac Book with iLok2. What caused this error? Did anyone encounter a similar issue before? Can somebody please tell me what could be done...
Read more
Hello Everyone,
I get an error when attempting to add (not load) a light from Render Studio for Poser 8 using ShaderWorks Library Manager. It is only adding light that give a problem. The rest of the processes can be done successfully on my machine. The error message says ‘temp_light.lt2’ file could not be opened. Is this an issue with the version of software I downloaded? Did anyone face a similar issue? I have attached a screen capture of the issue reported. How can I fix this issue? I am using Poser 8 on a windows 7 machine. Thanking you...
Read more
I get the following error from DreamMaker 3 when trying to add additional content files on Hybrid Dreams. The files I was trying to add were not in the same folder to begin with. So I copied the files to the folder with the dynamic content. Then I tried adding the files again. But even now, I get this same error message. Now what could be wrong? Can anyone give me a step by step guide on how to create a Hybrid dream, please? I am new to this application and could do with all the help that I...
Read more
Hi All,
When I am trying to record sound from a microphone using AudaCity and click record on Bandicam I get an error that says failed to start audio capture. I am using windows XP and trying to use Record sound from game option. I followed all the steps to perform an audio capture and tried applying the fix for setting the stereo mix setting properly. But I still cannot record sound. What is the mistake I am making? Can someone help me to resolve this issue please? Thanks a lot for the valuable help rendered. Regards
Read more
I am facing this problem for a third time on a trial version of Wondershare DVD Slideshow Builder. I wish I could be fully aware of what is causing this issue before I purchase this software. An error message is displayed when I attempted to launch the software. I was able to launch the program successfully once prior to this error. But later I keep on getting this error consistently. Why does it raise an issue regarding the space on E drive when the software is installed on my C drive? I don’t understand this and I am a...
Read more
I have been using USB Drive Antivirus for the last 6 months and am quite happy with this product. Yesterday, I got a network error when I tried to update the USB Drive Antivirus asking me to try later. But when I checked my internet connection, I could not find anything wrong with it. It was working and the speed was good as usual. I tried to update a little later and still ended up with this same message. Even after several attempts, I find that this update could not be completed even though I can download songs or...
Read more
Hello
I get the following error message when I try to launch a few applications like Dropbox and TimeMachine after upgrading to OS X 10.7. What is the problem with these files that is preventing them from connecting to server? I tried installing and uninstalling a couple of times. But this did nothing to improve my situation. Did anyone else face a similar problem after upgrading? And what are the applications using URLs with type “nwnode”. Am I likely to face the same problem with any other application I’m likely to use? Please advice. I have no idea regarding the...
Read more
I've got an error on Kollaborate Server. I used Post Haste for creating projects and this error keeps re-appearing:
Kollaborate Error
Project ID '0001' already exists. Please enter an ID higher than 0002.
OK
I don't understand the error so can someone please help me fix it? I don't have any duplicate projects created as to what I read on one site which may be the cause for this error.
Read more
After upgrading to Windows 7, my HP MediaSmart DVD 3.0 started to showed error. I want to know if there are other requirements needed to make MediaSmart runs on Windows 7? Or if it is compatible with it? Kindly send me some ideas. Thanks a lot!
MediaSmart DVD
Error applying transforms. Verify that the specified transform paths are valid.
C:UsersCopeDesktopTrialsp44452SourceHPMediaSmartDVDhptmpsrc1033.mst
OK
Read more
Hello
I recently started getting this error when I try to open ‘Transmission’ torrent on my Mac with Mountain Lion. The complete error message obtained is shown in the attached screen shot. After upgrade to 10.8.5, I face this problem. Earlier I was able to download and use the Transmission bit torrent on my machine without any issue. Is this a new change brought about by Apple? Does this mean I’ll no longer be able to use Transmission on my Mac? Or is there a way to override this setting. I would like to continue using Transmission torrent. Please can...
Read more
